hard to start
Old Sep 28, 2004 | 07:49 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by tdogg5.3
Man i have the same problem and i have been trying to figure it out for about a year now.
Truck starts fine in morning, drive to work, park it, Start truck up at lunch time and it cranks over like 10-15 times before it starts. heres what i have done.
change fuel filter
installed new FPRegulator
changed out vacumn hose
the weird thing is i pulled my vaccum tube off several times and never found a drop of fuel. WTF????
You might have a fuel pump issue...I've seen bad pumps act the same way, only instead of too much fuel, the issue is too little. If spark is good, I'd get a fuel pressure guage on there and see what you get after a hot soak. Vapor lock is another thing to consider.
Old Mar 16, 2005 | 09:11 AM
82lt1's Avatar
Did you guys ever figure out what's wrong with your trucks. I am having the same problem. I put a guage on it and it shows good fuel pressure when it's hard to start. I haven't checked the regulator yet, but will tonight.
Todd
Old Mar 16, 2005 | 09:23 AM
htsht's Avatar
Banned
Mine was the regulator. Put on a new one and it ran great.
Old Mar 16, 2005 | 09:39 AM
BigTex's Avatar
Just adding a note to this thread: When you pull off the vacuum hose, no fuel should come out. If it does, replace the regulator. That means under idle vacuum that the intake is actually pulling in fuel and running way too rich. The fuel pressure is probably way off as well.
Old Mar 16, 2005 | 11:51 AM
Onyx 02's Avatar
I've had to replace the fuel pressure regulator, 2 injectors, and drop the gas tank and clean it thoroughly, because of problems I've had with my '00 Z-71 running rough. Truck has 125k on it now and runs great. Just my 2 cents.
Thank god no problems with my '02, 105k miles and just now need to replace the brakes!!!
Old Mar 16, 2005 | 12:18 PM
82lt1's Avatar
I just pulled the hose off of my regulator, and there was fuel. I'm glad to see it too, because I didn't want to change the pump.
Todd
SLOPONY
20
Oct 18, 2016 06:05 AM
treylittlefield
Jan 24, 2016 07:38 PM
steves86ta
Jul 28, 2015 10:21 AM
Ketis
Jul 23, 2015 12:37 PM
banker099
Jul 4, 2015 05:50 PM
