hard to fill up gas
07 Tahoe 5.3 I see that somebody replaced new evap box canister, evap solenoid with line filter to gas neck, also new purge valve solenoid. After 1 gallon fill up then hard to pump take forever to fill up. What is the cause. I pulled gas neck hose to tank it look clean no clog, what it other most common.
Same problem with my 07 Tahoe 5.3, #1 cause = topping off the tank.
Replaced and installed the following and I have not had a problem since.
Vapor Canister Vent Valve ACDelco GM Original Equipment 23481275
AC Delco GM Original Equipment Vapor Canister Vent Solenoid Harness 19257603
