Half shaft and bump stop mod.
Old Jan 2, 2006 | 11:29 AM
04BlackGmc's Avatar
10 Second Club
Default Half shaft and bump stop mod.
Worthless while on Truck tb's?
Old Jan 2, 2006 | 11:40 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Some claim a SOTP gain with cleaning up the edges of the tb too.
Old Jan 2, 2006 | 01:15 PM
04BlackGmc's Avatar
10 Second Club
I see the bump stop does no good since i dont have a throttle cable.
Old Jan 2, 2006 | 09:39 PM
Dark Halo's Avatar
what are you removing when doing the bump stop removal?
Old Jan 2, 2006 | 10:40 PM
TXsilverado's Avatar
you remove a little bit of material from the throttle body where it stops the blade from opening any further. it allows the blade to open %100 but if you grind it too far you can confuse the computer...theres instructions on how to do it right using a volt meter somewhere in the forums...check ls1tech also.
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
trxmxzx
Sep 29, 2015 07:42 AM
