Guys with pacesetters
Old Jan 21, 2008 | 11:55 AM
rickyticky9849's Avatar
Registered User
Question Guys with pacesetters
I'm going to install pacesetters with my stock AC delco plugs and wires. Did you use any kind of heat insualtion for your wires? looking at the pictures it doesnt look like they will rub at all
Thank you
Old Jan 21, 2008 | 12:19 PM
circusboy's Avatar
I used stock wires for a little while. no shields, no problems. I switched to MSD wires.
Old Jan 21, 2008 | 12:21 PM
joshua022's Avatar
I use the stock shields and MSD wires.
I would use the shields on any type of wire you use.
Old Jan 21, 2008 | 12:33 PM
thunder550's Avatar
High on diesel fumes
I never used shields on my stock plug wires with Pacesetters and never had any problems. The only part of the plug wire that comes into contact or comes close to contacting the header primaries are the boots, and those are solid rubber and should insulate the plug wire enough that additional shielding is not needed.
Old Jan 21, 2008 | 12:35 PM
UBLUZIN03's Avatar
No problems here..ive had my pacsetters sence summer...
Old Jan 21, 2008 | 03:58 PM
outlawz2004's Avatar
I just ordered some long tubes also, most say use the heatshields on the wires, but I think I will see what happens without them. I will just use my old wires at first.
Old Jan 21, 2008 | 06:53 PM
Truckshop's Avatar
taylor wires fit good also. no shields needed
Old Jan 21, 2008 | 07:12 PM
Mangled03gmc's Avatar
Baltimore Whore
Nope no shields and just make sure the wires arn't touching the primes, you will be fine..
John
Old Jan 21, 2008 | 08:23 PM
guess im going to have to switch to msd wires. ive used bosch and borg warner and had problems with touching the headers
Old Jan 21, 2008 | 10:21 PM
silveradol33's Avatar
Stock wires. No problems.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
