Gutting a Cat
Old Feb 2, 2011 | 09:17 PM
02HD's Avatar
Default Gutting a Cat
I am running a stock 02HD silverado and I am wondering how you guys are not getting O2 sensor codes when you are gutting out your cats, also I was wondering how much gain in performance you are noticing. Oh by the way I am running the 8.1 with alli behind her.
Old Feb 2, 2011 | 09:46 PM
1SlowHoe's Avatar
Destroyer of Transmissions
You either turn the code off in your tune or you can run what they call "O2 sims". They trick the computer into thinking the cat is still there and working fine. Search for O2 sims and you can see what they do.
Performance? Mabey 5hp?
Old Feb 2, 2011 | 09:51 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Spark plug anti-foulers work for this also.
Old Feb 4, 2011 | 10:00 AM
02HD's Avatar
ok and how do I use a Spark plug anitfouler for this?
Old Feb 4, 2011 | 10:10 AM
ZR1 DREAMING's Avatar
Just delete them with your tune, that's the easiest and cheapest way. It won't run/drive bad with the code if you don't get it tuned out right away either.
Old Feb 4, 2011 | 11:54 AM
Rhino79's Avatar
9 Second Club
Damn I was hoping to come in this thread and learn how to properly filet a fiesty feline...****. Well in that case, like mentioned above, delete the codes. The antifouler has been used with much success by many, I have not ever used them so I don't know for sure.
Old Feb 7, 2011 | 07:44 PM
Found on Google in 0.18 seconds.....
http://www.preludeonline.com/f28/hom...ective-168992/
Old Feb 7, 2011 | 08:08 PM
AudioPh1x's Avatar
hahahaha
Old Feb 7, 2011 | 10:52 PM
jadaven's Avatar
I use a spoon
madmann26
Apr 29, 2020 09:17 AM
bagged7104SS
22
Oct 24, 2015 06:14 PM
BlownHD
Oct 3, 2015 12:24 PM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
