GRRRR, broken valvespring
single digit dreamer
how the heck does that happen? i got one and i am not real happy about it. i hope that valve isn't bent, i dont feel like pulling those heads again.
is there ANYTHING i could have done to cause this or is it just a bad spring?
i got the springs for cmotorsports, they are some off brand but they said they have had good luck with them, something like a ex616 or something, i will have to look them up.
Banned
the fact that they are an off brand could have something to do with it. from what i've seen in breaking springs, it's either that you're to close to, or above the maximum lift for them, or it's a combination of that and reving to high.
Bummer, I've had several of those over the past 4 years. Never did much damage and only had to pull the heads once. Mine were all the same brand and they claimed to have fixed the issue. I don't think its anything you could have done. Wonder what the manufacter date was for your springs.
As far as your head gasket woes. I went through several and everyone kept tellling me I had done everything right. (I was running a 250-350 direct port) Nothing seemed to work so in the End we were using 100ftlbs or so on the heads with O rings and Copper gaskets. That fixed it. A local guy makes the copper gaskets let me know if you want some.
my problem ended up being the head builder set them up to tight. they were beyond the tollerance of the spring. i broke 8 total and that included 2 inner springs. when i miked the install height i think it was like 1.740 whitch is tight.
i would say if they are settup correct then it was prob a combo of weak spring, to much rev/lift. also i learned to let the truck to get to 160* before driving.
i dont understand this at all, the springs are rated for 600+lift cams and i have a 595lift cam. only 2-3000miles on them. vavle doesn't seem to be bent at least. i can't get the cap and retainers out now, anyone have any ideas? i tried tapping on it and using some chanel locks too.
Its probably OK. Your piston may have a nice little smiley face on it now though. I haven't heard of that spring you are running.
For all the bad things thatpeople have said about the patriot performance heads, I've heard nothing but good things about their gold valve springs. Supposed to be good for .650 lift. Kit comes with springs, seats, retainers, and locks I think.
Are you able to compress the spring any?
that cap is just plain stuck on there, there is no spring holding it up either.
