Got a question
Old Aug 1, 2004 | 11:10 PM
ThunderZ28's Avatar
12 Second Club
Default Got a question
got a friend that is wanting to try out a cam but doesnt know how it will act in his 4.8L
it's a Lunati cam
specs are:::::
HYDRAULIC ROLLER: Good Pro-Street cam with choppy idle. Engine modifications required (valve spring). 2500-6000 287°
298° 222°
230° .534"
.544" .314"
.320" 114° Sep
110° Int C/L 01°BTC 41°ABC /
53°BBC -3°ATC
anybody got any Ideas????????
or should I try and post this in the internal motor section, and get razzed about, it.? I need answers, and not commits about go buy a bigger motor..
thanks,
Daniel
Old Aug 2, 2004 | 04:43 PM
ThunderZ28's Avatar
12 Second Club
no one?
Old Aug 2, 2004 | 04:53 PM
CHAGO's Avatar
Originally Posted by 01 Thunder
it's a Lunati cam
specs are:::::
298° 222°
230° .534"
.544" .314"
.320" 114° Sep
53°BBC -3°ATC
Is that hyroglyphics?
Old Aug 2, 2004 | 05:03 PM
zippy's Avatar
in a 4.8, that will make for a real high revving machine. on the other hand it's going to need alot of converter and will idle terribly without much vacuum.
Old Aug 2, 2004 | 05:51 PM
ThunderZ28's Avatar
12 Second Club
for you yes
for somebody that knows what thier looking at it is everything they need to know.
numbers where copied from Lunati\
thanks for the imput
I hadnt heard anybody with this cam, and didnt quite know what to think of it.
I was also thinking it would need a high stall, but didnt know what the divability issues would be like.....
thanks
Old Aug 3, 2004 | 02:27 PM
BigKID's Avatar
222/230 .534/.344 114+4... That seems like a lot of duration for a 4.8 but the low lift numbers make me think that the lobes may be fairly mild. It has a good lsa and advance to keep the power down some but he is definately going to need a good bit of converter to make good times with it.
Old Aug 3, 2004 | 03:06 PM
marc_w's Avatar
Yeah, the ramps look to be on the slower side. I think he'll be better off with your cam if he wants to be in that range of duration. (Maybe point him to TSP if you don't want any clones in your area.
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
