Got a problem with the new 408
Old Jul 20, 2007 | 10:09 AM
BlownChevy's Avatar
blownerator
25 Year Member
either you have one hell of a starter, or you have no compression on two or more cylinders.
Old Jul 20, 2007 | 10:23 AM
Tootall's Avatar
no kidding, your starter is zinging FAST !
Both times when you clicked your ignition over, I couldn't hear the injectors, or the FP.
Are all of your plugs in and tight? . . . . how big is your battery, your starter really kicks over fast.
Old Jul 20, 2007 | 10:34 AM
Quik's Avatar
5 year bitches!
mine fouled plugs at first and wouldnt start
Old Jul 20, 2007 | 11:55 AM
BlownChevy's Avatar
blownerator
25 Year Member
go home and check your compression on each cyl. I bet you find 5 or more dead holes.
Old Jul 20, 2007 | 05:19 PM
mwalls54's Avatar
Need More N2O Mod
Well I ran across a couple of things, first i did a compression check on #1 and #3 and they both put out about 30psi. not good. well i poped the valve cover off and pulled the rockers off and bam 130psi. so i know now its either too long push rods or the cam is off. well i took the front off and sure enough the adjustable timing chain adjusted itself and was off about 4 or 5 teeth. so i put the stock cam gear back on and realingned it.
Old Jul 20, 2007 | 05:27 PM
BlownChevy's Avatar
blownerator
25 Year Member
:yawn: whos your daddy now biatch?
Old Jul 22, 2007 | 01:45 PM
mwalls54's Avatar
Need More N2O Mod
well the cam being out a little bit wasn't it. i ended up backing the rockers off about 2 full turns on the bolt and i have full compression so i just ordered some pushrod length checkers. Hopefully that will take care of my problem.
Old Jul 22, 2007 | 03:22 PM
Flyer's Avatar
THe fuel pump will come on and go off. It has a 3 second period of coming on with the key. If the start isn't engaged, it will not continue to go. It's pretty much just a prime cycle.
The FP dropping sounds like maybe a busted oring in the regulator.
Old Jul 22, 2007 | 06:12 PM
mwalls54's Avatar
Need More N2O Mod
I wasn't getting any pressure at the fuel rail, the pump made a crazy loud hum, 10x's louder than normal before it quit. i replaced it with a stocker and i got pressure now.
Old Jul 27, 2007 | 12:04 AM
mwalls54's Avatar
Need More N2O Mod
well after getting the pushrod length checkers in and measuring. it wasn't the pushrods. so i start thinking and put the motor at tdc according to the timing marks on the timing gear i realized it really wasn't tdc. i had a piece of copper wire sticking down in the spark plug hole and i turned the motor over by hand and about a half a turn i finally reached tdc and the timing marks are no where near each other. so i lower the oil pan and pull the oil pump and sure enough the crank timing gear was put on wrong(not by me). so i put it back on right and got the cam lined up and bolted everything back together and one turn of the key it started right up.
