Got a problem fellas
Old Oct 27, 2007 | 11:54 AM
zmonsterjb's Avatar
Default Got a problem fellas
I have a 2003 Yukon 2wd flex fuel truck.
It surges or idels bad. Needle hangs around 500rpm. It seems to want to cut off at lights but dosnt, although it does cut off when slowing down in a turn. Its also causing electrical problems in the truck as when it surges the charge jumps up and down.
It is EC Throttle , can anyone give me some pointers.
Old Oct 27, 2007 | 12:36 PM
zmonsterjb's Avatar
up date, it surges at idle now and if i turn the sterring wheel it will die.
Old Oct 27, 2007 | 01:12 PM
adam1803's Avatar
And its not throwing any codes? I would check your TPS and IAC sensors. BTW, are you in Marianna, FL?
Old Oct 27, 2007 | 08:01 PM
zmonsterjb's Avatar
Yukon is ETC, and nope it was not throwing any codes. Turned out to be carbon build up between the throttle blades and the bore. Did not even look like a lot, but I cleaned it anyway because I was running out of ideas with brake cleaner and a bore brush, and it fired right up.
Actually I am in Ft. Rucker. going to flight school. Are you a pilot, crewcheif, or a medic, asking because I noticed your thread. By the way I used to be medic, and I will be flying Black Hawks when I get home.
Old Oct 27, 2007 | 10:39 PM
adam1803's Avatar
Glad you got it figured out, i forgot that it was ETC. I was a Pave Hawk mechanic for about 5 years, then i retrained and i'm an air traffic controller now. Good luck
Old Oct 28, 2007 | 01:28 AM
zmonsterjb's Avatar
thanks, any good tuners in that area
Old Oct 28, 2007 | 09:22 AM
adam1803's Avatar
PM sent
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
