got the pacesetters and ory installed!
Old Aug 6, 2005 | 08:49 PM
CrazyAggie05's Avatar
Default got the pacesetters and ory installed!
well it took all frakin day but i finally got them in. waht a pain in the ****! note to self: if i ever do this again, make sure it is on a new truck with no rust on the flanges and get a set of air tools!
i took it for a spin with just the headers on and holy $#@ this thing sounds crazy! i put the ory on and it tamed it a bit, but i cant seem to get the y-pipe to seal well. i got the good band type clamps, but they dont seem to hold the pipe on well even when i get them as tight as i can. am i doing something wrong?
oh the sims i got have male connectors? while the sensors they are replacing have female? so i cant plug the sims in, i guess they sent the wrong ones! it hasnt thrown a code yet so i guess it aint a biggie.
next is a magnaflow i think, i wanna be able to hodl a convo on the highway! time to go drive some more!
Old Aug 6, 2005 | 09:50 PM
Okie5.3's Avatar
are you using the pre-formed band clamps? those have a step-down fabbed into them for the OD/ID connections. i also took a hacksaw and cut 4 small slits in an X/+ fashion on y-pipe where the collector slips inside. this will allow the y-pipe to collapse around the collector and seal pretty good. only made them about an 1 1/2" long so they would not extend pass the band clamp.
Old Aug 7, 2005 | 01:36 AM
TigerFan187's Avatar
I cant wait to get my Pacesetters and Magnaflow on as well as getting those filthy cats chopped off!
Old Aug 7, 2005 | 11:32 AM
blk03's Avatar
yeah, I have not got mine to seal completely either. I am getting a small leak on the driver's side. I am going to do something to remedy the leak but have not decided what. I am going to try to get some flanges welded up or something.
Old Aug 7, 2005 | 12:13 PM
duwem's Avatar
I saw in a magazine install where the put some like RTV Silicon Hi Temp adhesive on the exhaust pipes before the stuck them together to prevent leaks, I would look into it.
Old Aug 7, 2005 | 01:20 PM
hmmm i think ill try cutting those slits, if that doesnt work, then i will try the sealant, and then if that doesnt do it, i guess ill have to get flanges welded on.....oh well...id kinda like to get the y-pipe modded anyways later on...right now i have a single 3" cutout after the y-pipe, but iw ould like to have a cutout after each header, and id also like to have a spot to put at least one removable cat that way when inspection comes around i cant be leagal. damn i freakin love this thing!!!!! oh, and i was also thinking of getting it tuned since all i have now is this crummy hypertech....is getting a real tune gonna really help out with headers and such?
Old Aug 7, 2005 | 04:46 PM
Im getting mine port matched!
Old Aug 7, 2005 | 06:07 PM
is that where they machine out the oval exhaust ports on the block so they match the circle ports of the header?
Old Aug 8, 2005 | 04:57 PM
well after driving around for 2 days i must say im rather disappointed at the low end...it feels like i lost some...i havent done too much high end driving but it does seem to pull a little harder up high. the clamps are definately not holding so today i will cut some x's in the y-pipe like suggested....
i am a bit concerned because it smells and feels like it is running really rich. i think im gonna get allen at nelson tune to tune it this week when i go home to san antonio. also, im not running any sims cuz i got sent ones with male connectors and i need female...so i have the rear sensors hooked up, but im not getting any codes...whats up with that?
Old Aug 9, 2005 | 06:08 PM
blk03's Avatar
would napa, oreilly's, autozone, pep boys, etc carry the permatex hi temp ultra copper rtv silicone?
I think this would solve my problem for now. I may get a custom y made with cats later down the road.
