Got my TURBO on my Yukon Denali - Great Job Livernois Motorsports !!!
Old Apr 16, 2005 | 02:53 PM
  #31
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I want one.
Old Apr 16, 2005 | 07:18 PM
  #32
LivernoisMotorsports's Avatar
LS1TECH, Trucks, Modmotor Sponsor
adrianmt75, The kit sells for $4,995.00 and includes:
  • Polished Garrett Turbo
  • Black Powder Coated Inlet Tubes
  • Black Satin Ceramic Coating on Hot Parts
  • 42 lb Injectors
  • 3 Core Air-to-Air Intercooler
Dual 4 into 1 Tubular Headers w/ 1 5/8" primaries, 1/2" Laser Cut Header Flanges, 2 1/4" Cross Over, 3" Down Pipe, Powder Coated Inlet Tubes, All V-Band Connections, High Quality Silicone hoses w/ Aircraft Grade SS clamps, Tial 38mm Billet Wastegate, and complete detailed instructions.
* Bolt-on Installation; NO SHEETMETAL CUTTING OR WELDING required! Works with factory electronics.
The Battery, A/C, Power Steering, ABS, etc.. remain in the factory locations, so you could put your car back to stock, very easily at any time.
We recommend a shift kit which would add an additional $300 to the cost of the kit.
The turbo is a GT-37 with a custom exhaust housing, however upgrades are available.
Regards,
Rick LeBlanc
Old Apr 16, 2005 | 07:31 PM
  #33
GoldenVelvet's Avatar
It doesnt come with a fuel pump? Is one needed? And how do you go about retuning for the injectors?
Old Apr 16, 2005 | 07:41 PM
  #34
niwtsol's Avatar
where are you located. my tahoe could really enjoy this
Old Apr 16, 2005 | 08:04 PM
  #35
We ran the stock pump with the base turbo and 5-6 lbs. When we put the larger turbo on we added a Walbro 342 in-tank pump. If you are local we can flash your ECM or you could send it to us.
niwtsol, We are in Dearborn Heights, MI (near Detroit)
-Rick
Old Jul 19, 2005 | 08:30 AM
  #36
anders's Avatar
Default Great support Livernois
I am very happy with Livernois and their kit. Must have put 10,000 miles on it already and it is flawless.
Power is addicting. I received a quote for adding some boost, up to 8-10 PSI somewhere. Pump, programming, etc. Might go for it. Anyone running this boost level on a otherwise fairly stock 6.0L engine?
Anders
Old Jul 19, 2005 | 10:49 AM
  #37
Wilde Racing's Avatar
How do I change this text
I'm running 10psi in mine. but isn't yours a LQ9?
Old Jul 19, 2005 | 11:18 AM
  #38
1slow4.8's Avatar
I'm praying to the smog gods for a carb e.o.# Making big power in cali is frustrating.
Old Jul 19, 2005 | 07:22 PM
  #39
03sierraslt's Avatar
I am running 6 right now however I am going to be bumping it up to 8 real soon. Wanted to this week but have been to busy. A buddy of mine is running 8 via a Whipple on his Yukon Denali.
Old Jul 19, 2005 | 09:14 PM
  #40
bud8fan's Avatar
Anders
i ran 8 to 10 on mine also...worked real well
