Got my HPtuners today
Old May 24, 2004 | 06:49 PM
  #21
FILE's Avatar
Originally Posted by Black02Z71
I finally got to play with HPtuners today, I was up north at the cottage this weekend getting eaten alive by black flies.
HPtuners rocks, I can read the pcm in less than 2 min, and write in 27 sec. The scanner that comes with it is pretty basic, but they are working on adding to it, like there is a pcm control button on the scanner, if you click on it, it says feature not yet implemented, so there working on it. HPtuners can only get better.
What I have adjusted so far. Working off Predator tune
RPM limit
shift points
raised idle speed
Low and High octane table (Copyed high table to low -2)
added 2 degrees across high table
- LTFT (scaled IFR vs kpa using spead sheet)
tuning_1.0.2.xls
- PE table (X93%)
knock learn min rpm 7000
abuse mode 7000rpm
disabled ses on PO300
HPtuners forum
How did you delete the PO 300 code. I have this same code becuase of the cam and would like to get rid of it. I just don't want to compretely get rid of to where even if there was a dead on misfire (i.e. plug pulled out) it would not turn on the SES or throw the PO 300 again.
  #22
Black02Z71's Avatar
I can really feel a difference in power. The biggest change in power is from pulling PE, the O2 were way rich and it still is .930mv-.950mv and I know O2 aren't accurate.
Yes you can tune a supercharger, you can change everything you would ever need or want to change.
Attached Thumbnails Got my HPtuners today-scanner.jpg   Got my HPtuners today-scanner22.jpg   Got my HPtuners today-editer1.jpg   Got my HPtuners today-editer22.jpg   Got my HPtuners today-editer33.jpg
Old May 24, 2004 | 07:15 PM
  #23
Black02Z71's Avatar
Here is a log file exported from the scanner. If you have a spreadsheet program, then right click and save target as.
log file
Attached Thumbnails Got my HPtuners today-editor44.jpg   Got my HPtuners today-editor5.jpg   Got my HPtuners today-editor6.jpg   Got my HPtuners today-editor7.jpg   Got my HPtuners today-editor8.jpg
Old May 24, 2004 | 07:22 PM
  #24
Black02Z71's Avatar
I first tried setting all points in the low rpm misfire table to 32000, and it didn't work so I turned the code off.
Old May 24, 2004 | 10:50 PM
  #25
ToXicD's Avatar
great posts man, i am getting hptuner soon and this information will be very helpful, thanks.
Old May 28, 2004 | 05:28 PM
  #26
marc_w's Avatar
Got mine today for my '04.
I have to say, this is the coolest thing I've bought in a LONG TIME.
Even dumb*ss me read the VCM and started logging stuff five minutes out of the box, and without looking at help files.
My read took about 10-15 minutes at the most. Every once in a while it would try to go to a high-speed mode, and things would start clicking in the dash, and it'd go back to normal speed. If it stayed high-speed, I'm sure it'd fly.
The logging software is awesome. I was here thinking I'd need to set up parameters to log and set up CSV's myself... NO... it's all done automatically. It'll take a pretty good idiot to mess this stuff up.
Off to log some data!
Old Sep 10, 2004 | 09:09 PM
  #27
Well, I'll tell you, I got this thing today and I'm totally lost. All I got was a cable and a cdrom. Are there instructions somewhere? I have to assume that when you folks said "it comes with a scanner" you meant a program that you download into a laptop that can be used as a scanner right? I want to make sure I'm not missing something.
Old Sep 10, 2004 | 09:27 PM
  #28
Sport Side's Avatar
download that cd onto your lap top. you might have to go buy a USB connection.
Download it on your home computer too. It works real well to hook up both in one room and have all your logs on one screen while your making a .bin file on the laptop.
Old Sep 10, 2004 | 09:33 PM
  #29
I just found the instructions on that disc. I'll read it and give it a try in the next few days.
Old Sep 10, 2004 | 09:38 PM
  #30
Sport Side's Avatar
cool. feel free to ask questions. its a bit tough getting started.
Porscharu914
14
Jan 20, 2016 10:45 AM
Avalanche2002
Nov 30, 2015 07:31 AM
cheyenne383
Nov 13, 2015 09:24 AM
trxmxzx
Sep 29, 2015 07:42 AM
