Got a minute to help me out? Please give me advice!
Old Apr 9, 2015 | 09:22 PM
  #31
GREENSIERRA's Avatar
35"s and 4.56s only brings you back to about stock
you say you want 0-80 to be quick and honestly gears is whats gonna do it for you. you want everything but don't want the down fall of it. not being a dick what so ever just telling you how it is.
minimum 4.88s but 5.13s would be what you want. couple that with a higher stall and cam to match and it will be a lot of fun
I have ran a 5.3 with a tsp 220 and a 3200 with my 36"s and 5.38s and yeah it was fun, after that I had a 5.3 with my current heads, 3600 stall, eps 223-226 610-605 110+4 and that was a lot more fun then went to a LQ4 with my current heads, LSXrt intake, eps 230-238 604 113 and a 4000 stall, 10.8 compression and that setup would surprise people all the time. haven't tried my new setup yet.
with all those setups my gears and converter selection is what really got my truck out of the hole hard and then cam selection helped to keep those heavy tires rolling uptop
Old Apr 9, 2015 | 09:24 PM
  #32
oh yeah, all those setups where DD. only vehicle I had to drive and with proper maintenance I never had any problems at all even with beating on it every single day more then once
Old Apr 10, 2015 | 01:32 AM
  #33
04silvy1500 2wd's Avatar
The way I see it is my gears arent changing any time soon because it'll kill my gas and I don't want to change my stall I just bought a couple months ago so I guess I'm just looking for help on building a good solid motor that will give me what I want. High compression and high torque. And I know this won't get me 0-80 real fast but maybe it'll be enough to put me back in my seat.
Old Apr 10, 2015 | 09:50 PM
  #34
01silvy's Avatar
Your concerned about gas mileage but you want a truck that will 0-80 quick. It takes fuel to move quick. You have to decide if gas mileage is more important than going fast. If gas mileage is a high priority, ditch the 35" tires... 6.0's aren't known for their gas mileage either.
Old Apr 11, 2015 | 10:23 PM
  #35
exactly, like I said you cant have it all without downfalls.
the 2 things that will get you what you want you don't want to do.
Old May 10, 2015 | 12:29 AM
  #36
bottomline2000's Avatar
Originally Posted by 04silvy1500 2wd
This is my list so far! What do you guys think? Or what would you change? Remember I live in California so small is a factor and its my only vehicle so I can't stress reliability enough!
LQ4 long block $800-1500
Motor swap +cam install + tune $2000
243/799 heads $300+ machine work& valves
Arrow engines and machine shop Temecula
10295
Cast Iron & Aluminum Oil Pumps
Cam "The Trucker"
LS TRUCK CAMSHAFT
Hardened pushrods
LS Chromoly Pushrods 3/8" Diameter, Set of 16 - Brian Tooley Racing
Valve springs
Texas Speed and Performance - PAC 1218
Trunion upgrade
Lunati GM OEM LS1 Rocker Arms with Upgraded Trunions
Ls2 timing chain
Cloyes LS2-4x Hex-A-Just True Roller Single-Roller Timing Set, Includes Z06 Chain, 3-Bolt Cam
interesting we are building a similar setup. I'm using the Vinci truck cam and also have a 26-2800 stall going into a NBS Tahoe. Couple of things I noticed is the cam card from vinci recommend dual springs. Also the cam gear you listed seems expensive. I bought the dual springs, trunion upgrade and cam gear from brian tooley. It's billet and adjustable (not that its needed)and less than $100. seemed silly to cheap out on the trunion upgrade with all I've spent on everything else. Also Tooleys trunion upgrade comes with new rocker bolts vs comps. My goals are similar to yours only that I plan to
throw a blower on top of it as soon as I find a good deal on one
also, I have 317 heads on my lq4 and 3/8 pushrods seems to be no bueno without a little clearance on the heads..stock is 5/16.
https://www.performancetrucks.net/fo...estion-534767/
good luck with your build!
Old May 10, 2015 | 09:37 AM
  #37
TXsilverado's Avatar
I love threads where someone asks advice, then refuses to accept experienced input on what would work best.
Old May 10, 2015 | 03:27 PM
  #38
CSpencer04's Avatar
If you want reliability I would definitely invest in some good bearings like clevite h series regular or coated. I have the coated ones and beat the dog **** out of em and they have barely worn. That and some ARP rod bolts and you'll have a solid bottom end for your application.
thompson
Dec 27, 2017 06:48 AM
bearden86
26
Nov 15, 2015 03:58 PM
Chevy305
Sep 28, 2015 09:21 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
