Got killed..Help
Old Jan 19, 2004 | 12:56 AM
gibbs6's Avatar
Default Got killed..Help
Well I got beat by my friends 02 rcsb 5.3 today. I have a 00 rcsb 5.3 also. He got me by half a car to a full car length. The problem is his is stock with just a flowmaster exhaust, 3.42's with the stock locker G80? While I have intake, pulleys, exhaust and 3.73's with a eaton locker.
I am nearing 80,000 miles while he is only at 35,000. I raced with a 3/4 full tank and he had 1/4 and I had a passenger, but it should not make that much of a considerable difference? Last time we raced. I got him by a car and a half (this was without the 3.73's and locker, just stock 3.42's and open rear).
I know the amount of gas and passenger hurt me but not by that much I don't think. Maybe its a mileage issue? Also one friend we race sometimes with a rcsb 4.8l I beat by 3 cars just with exhaust and nothing else, he only beat by a car.
Just shoot me some opinions on this and such as I am lost and confused and upset as $1300 dollars got me jackshit it seems. Thanks
Old Jan 19, 2004 | 01:07 AM
Usually 100 pounds = ~.1 in the quarter. The passenger and extra gas were hurting you pretty bad... lose the passenger and run him again, should be a lot better race!
Old Jan 19, 2004 | 01:09 AM
gibbs6's Avatar
Around half a tank more and a 190 pound passenger. I just thought I would get alot more out of the gears than what I did.
Old Jan 19, 2004 | 09:28 AM
gonzo 6.2's Avatar
You need a westers PCM
Old Jan 19, 2004 | 09:39 AM
6gear's Avatar
I agree that the extra weight is what got you.
Old Jan 19, 2004 | 09:55 AM
How did you and he leave the line?An inch at the start=?feet at the 1/4.
He has the gearing advantage after launch.
1/2 tank gas =?85#, passanger 200#. How much HP is the pully worth?
Sounds like you guys match up pretty good,you won the first time,why would he tell you if he changed a little something?
Keep Racin'
Scream's Avatar
MOOBIES Moderator
The '02+ trucks are just faster. No one really has a good explanation. The only thing that I know is different is that they don't have EGR.
Old Jan 19, 2004 | 09:59 AM
Sport Side's Avatar
will removing the egr from the exhaust manifold and shavin a bit off the hose that sticks in the intake throw you codes?
Old Jan 19, 2004 | 10:07 AM
Scream's Avatar
MOOBIES Moderator
Yes. You would have to have EDIT to turn EGR off.
I still think that there's more to it than that, though. I think that the General was holding out on us. Those trucks HAVE to be making more than the 01 and later trucks, but the 02+ are rated at the same HP and TQ, at the same RPMS if I remember correctly.
Old Jan 19, 2004 | 11:44 AM
LOW2000's Avatar
My truck is very weight sensitive. I know the general formula is .1 per 100lbs in the 1/4, but with my g/f in the truck when I race in the 1/8th i'm about .3-.5 slower, and she certainly doesn't weigh 300-500lbs.
