Good cam choice?
Old Apr 26, 2014 | 10:31 AM
bearden86's Avatar
Default Good cam choice?
Hey guys I have a 06 sierra CC Z71 5.3. I have come across a pretty good deal on a comp cam specs are. 210/218 at .050 .596/.591 110LSA with 2 degrees advance. My plans for the truck are headers cam and tune at the moment. I do use my truck to pull my quad rarely will I pull over 4000 pounds. I want to keep my stock stall until I have a reason to take the transmission out. So for a DD with light towing would this be a suitable cam with noticable gains.
Old Apr 27, 2014 | 01:26 PM
Fast_six oh's Avatar
That sounds like a nice cam for what your are wanting to do with the truck..should have real good bottom end torque..a higher stall converter will give you the full use of the cam though..
Old Apr 27, 2014 | 02:03 PM
gnd111's Avatar
I won't go that radical lobe spacing for a daily driver myself.
Old Apr 27, 2014 | 06:49 PM
Id say around a 113-114 lsa
Old Apr 27, 2014 | 11:01 PM
Vortec350ss's Avatar
Yea with a 110 LSA it will still have decent chop even with such small duration. It's inly -6* of overlap. It will make the chop felt through the stock converter unfortunately.
It'll make a real strong mid range and probably sign off 'early' but I'd expect it to pull 6k no problem.
Old Apr 28, 2014 | 09:31 AM
69Camaro427's Avatar
I just installed a 210/218 .584/.584 on 116lsa and love it, so much lowend tq with the stock stall and a very noticeable mid/top end improvement over the stock cam
Old Apr 28, 2014 | 10:14 AM
bearden86's Avatar
where did you get your cam from?
bearden86's Avatar
Thanks for the input guys!
Old Apr 28, 2014 | 12:25 PM
Vinci cams and my cam is a .551/.551 lift, but I have 1.8 roller rockers for the .584/.584 lift.
Check out the thread "Got the cam in a tuned last night. Videos" in the internal engine section. I have all my mods listed with some WOT and dd videos.
Old Apr 29, 2014 | 01:01 PM
turboal1's Avatar
Default comp cam
I run a Comp cam .210/.224 .560/.580 116 C/L
1500-6600 stock conv. and it tows fine
