gonna try the Diablo
Old Oct 24, 2002 | 11:06 PM
Brandon Boomhauer's Avatar
Default Re: gonna try the Diablo
thanks
Old Oct 27, 2002 | 12:26 AM
SlobnobberGT has a <img border="0" alt="[gay]" title="" src="graemlins/gr_rainbow.gif" /> pride sticker onhis moms 3cyl. Ford Festiva
Old Oct 28, 2002 | 03:38 PM
MiSdIrEcTeD_1's Avatar
Hey... Let me know what all the diablo does... Can you change your speedo for different sized wheels and tires? And also lemme know if you can set it up to run a lower thermo... And,once more, lemme know if it changes your ignition or w/e to run higher octane....
Old Oct 28, 2002 | 04:07 PM
RED2K's Avatar
yes you can change tire sizes. you can raise your speed. you can change your timing and air to fuel ratio, down load off a p.c, set temp for e-fans, change tranny settings,line pressure,shift points and etc... fuel types, remove ses lights. trouble shoot and read kinda trouble codes. you can also get custome programs for this like getting rid of t.m.
Old Oct 28, 2002 | 04:22 PM
Sounds like one should spring the extra money for a diablo over a HPPIII then, huh??? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 28, 2002 | 04:25 PM
RED2K's Avatar
one would think
Old Oct 28, 2002 | 04:39 PM
SSHOTRODSCOM's Avatar
The TQM is removed on the base loads. No need for a custom program.
John Cannon
www.sshotrods.com
Old Oct 28, 2002 | 04:54 PM
GREGGO's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSHOTRODSCOM:
<strong>The TQM is removed on the base loads. No need for a custom program.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Are you saying we can loose TQM with the Diablo? I thought that was only possible with LS1 Edit.
Greg
Old Oct 28, 2002 | 05:19 PM
GREGGO's Avatar
Nevermind I did the looking into. Looks like I may switch to it too. At least that way I can proceed with my tranny upgrades before the motor swap.
Greg
Old Oct 28, 2002 | 05:28 PM
norcal5.3's Avatar
someone at ls1.com said a 4.8 gained 40 hp from the diablo tuning.... I believe Red2K said he was going to get it dynoed I might switch too if I don't get laid off first.....
