Goal low 13.0's 5.3
Old Aug 10, 2009 | 07:44 PM
Amedee's Avatar
Default Goal low 13.0's 5.3
06 gmc sierra extended cab 5.3 with intake longtube headers and 3' y pipe what size cam torque converter etc do i need to get my truck in the low 13.0's its a 14.5 now. SUGGESTIONS?
Old Aug 10, 2009 | 07:52 PM
00ChevyScott's Avatar
Wearin' da big hat
My setup has been there twice, but I've learned one thing. The bigger cam you put in it, the more head work you'll need.
My 216/220 cam with my 3800 converter ran an 8.3 (around 13.0-13.2) in cold weather with stock heads. I haven't had a chance to run the new setup, 228/228, in colder weather, but my best times have been around 8.5 (13.4-13.5) in summer heat. The heat/larger cam killed my low end and hurt my 60 ft. But this is where a good set of heads and higher compression come in. It's gonna help me get more low end power, as well as helping out the top end alot. I hope to hit 12s with the new setup + heads.
But I'd say a good proven set up would be around a 220 or 224 duration cam and a 3600+ converter with 4.10s and drag radials or slicks.
Old Aug 10, 2009 | 08:01 PM
grey matter 04's Avatar
13 Second Truck Club
About time you made it on here.
get that yank 3000 from cade
Its a good converter
Old Aug 10, 2009 | 08:07 PM
Amedee's Avatar
Thoughts on 3.73 gears a 220 cam with a 3000 converter stock heads for now.
Old Aug 10, 2009 | 08:08 PM
Wearin' da big hat
I don't see that hitting low 13s. I think you'll need a looser converter to pull the 60ft needed
Old Aug 10, 2009 | 08:15 PM
4.10 gears
3600 stall
tr224 camshaft....same cam as slim
should do low 13s or high 12s
there is a guy on here with that setup and it runs 12.8s
Old Aug 10, 2009 | 08:17 PM
Wearin' da big hat
Originally Posted by slow n low 4.8
4.10 gears
3600 stall
Who are you thinking of? Because the only guy with an ECSB 5.3 N/A running those times has heads as well.
Old Aug 10, 2009 | 08:20 PM
01 body style blue and gold xtra cab chevy
dont know his name
Old Aug 10, 2009 | 08:22 PM
cwalker2006's Avatar
not hijacking but u think ill see low 13s with a 220 cam 3000 stall 4.10s and 100 shot?
Old Aug 10, 2009 | 08:23 PM
Wearin' da big hat
yes, I'd say you'd see mid-high 12s if you spray out of the hole with traction
