gmc problems
Old Sep 30, 2008 | 05:00 PM
redsilverado05's Avatar
Mine spits, sputters and back fires under a load, and doesn't want to idle as well. It also seems to be burning a little more fuel and something seems to be rattling from under my floor board when idling. I check my spark plugs and 3 were fouled. I repaced them and it does run better but not like it should. Also, I checked my MAF and it's clean as a whistle.
Old Sep 30, 2008 | 05:16 PM
blueflamed03's Avatar
get this at like O Reilly's, NAPA,etc...and get some good carb cleaner. Take off CAI, and take off MAF and use this cleaner. Then, with the Chemtool, what I used, and get a screwdriver, open the throttle plates of the TB, and spray in there and get it good and clean. You may get a rag and wipe out any larger black suit. But clean well, leave it open to air out, spray of MAF, and reassemble after 5-10 min.
Worked perfect and fixed mine.
Old Oct 1, 2008 | 12:30 PM
budhayes3's Avatar
PT's Slowest Truck
Do you have cats? I wonder if your cat converter has broken up and is rattling and plugs the exhaust outlet under load.
Old Oct 1, 2008 | 01:43 PM
Nope no cats. I'm wandering if I could have gotten a hold of some bad gas somewhere, or it just needs a re-tune really bad. Other than that I'm thinking it's either a bad sensor or a vacum leak somewhere.
creekrat
Sep 10, 2015 12:59 AM
custm2500
Sep 8, 2015 05:53 PM
bisqikss
Sep 8, 2015 03:35 AM
the owl
Sep 4, 2015 04:09 PM
Hpinnovate
Sep 4, 2015 02:28 AM
