GM Cranks Sizes
Old Jan 21, 2018 | 12:46 PM
KleanKustoms's Avatar
Default GM Cranks Sizes
I know this has been asked time and time again but I can’t find the answers I’m looking for. I know the 6.0’s in 99-00 had a little longer crankshaft, but is this the same for 4.8/5.3’s that are 99-00 or are all these cranks the same size?
I have the chance to maybe buy a 99 4.8 to replace my blown 5.3. It will be coming out of 2005 rcsb, with a 4l80e swap.
Old Jan 21, 2018 | 09:00 PM
1FastBrick's Avatar
Custm2500's Rude Friend
If you are referring to length at the tail end, Only some of the 4.8L cranks had the longer rear snout on the crank. I believe they were paired with a manual trans in the truck applications for 99-00.
If the 05 engine and trans combo was originally from a van it should already have the spacer and flat flywheel on the crank. If it was originally in the truck and he swapped in a 4L80E anything is possible.
ltr450ryder
Nov 30, 2010 07:39 AM
Slammedchevy01
17
May 4, 2005 03:02 AM
