Gen IV 5.3 Swap to 6.2. Help!
Old May 16, 2018 | 04:59 PM
EVandy's Avatar
Registered User
Default Gen IV 5.3 Swap to 6.2. Help!
Alright boys and girls I have a lot of questions and would like to knock as many of them out in one post. I have a 2WD 2012 Silverado 5.3 with 3.42 gears. My plan is to swap in a L9H 6.2. I know these motors are extremely similar but was just curious if there are any minor things to look out for when performing the swap. I’ve done a couple of swaps in the past but it was always just replacing the motor with what was already in the vehicle. Also before dropping in the new motor I was planning on refreshing it a bit. I want to tear into the motor and clean and replace some things. Just curious what I could replace to extend the life of the motor and possibly make it run a little better. I want to add some performance as well without sacrificing much if any drivability. I drive roughly 25k-30k miles a year and occasionally tow with it. I’m keeping the stock cam without question but was just curious what else could be done outside of forced induction. I know basic bolt ons and good tune but was just curious if I could do anything else internally while supporting the stock cam. Also would it be worth the money to swap my 3.42 gears to 3.73 or just go for 4.10? Keep in mind how much I drive. Don’t really have a budget just want it all done right. Apologies for the the long post and thanks in advance!
Old May 16, 2018 | 05:12 PM
FFDP's Avatar
This is just my opinion here so take it as that and an option for what you are doing.
If you want it to be simple as simple gets the straight swap is the easiest thing to do. It's not even worth it to open the engine up if it's a known good running engine. New gaskets and seals is a great idea still though.
I don't see where you'd gain much doing anything if you aren't actually swapping in performance parts. The biggest gains are in the tune in stock form, a decent tune on the 6.2 and the good transmission tune on that 6L80e will make it drive awesome. Going to 3.73 or 3.90's would be great too if you want to keep the highway rpm down. Though 4.10's might not raise it that much over the other two options. You can figure out engine rpm through various online calculators and you will need to know the final drive ratio of 6th gear for that.
Old May 16, 2018 | 11:32 PM
EVandy's Avatar
Registered User
Okay awesome! Thanks for the input! 3.90 will probably be the route I go. Split the difference between 3.73 and 4.10. And yeah I figured I would be limited to headers and a good tune without any major engine renovations. I would eventually like to throw a blower on it but that’s for a later date! Thanks again!
Old May 18, 2018 | 03:28 AM
swathdiver's Avatar
5 Year Member
Change the pick up tube o-ring and put the new one in right. Check the oil pump out. Dual valve springs?
I'd leave the 3.42 gears, you're already adding about 100 horsepower with the tuned L9H, it'll have plenty of power and not siphon off as many of the greenbacks in your wallet as it will with a lower ratio gear when you fill up.
Old May 18, 2018 | 05:56 AM
1994Vmax's Avatar
Less gear does not mean better fuel economy... do the gear swap and enjoy the power.
Old May 18, 2018 | 10:26 AM
turboal1's Avatar
Default Swap
I did this swap last summer. just added a cam.
it was a low mi eng. swap was a PNP. just need
to tune it after swap. see my sig for info on truck
Old May 18, 2018 | 02:04 PM
swathdiver's Avatar
5 Year Member
Since when?
However, every engine has its most fuel efficient operating range. I had an LZ9 motor that got better mileage at 77 mph than at 70 mph and running it at 90 mph was only 2 mpg less than it's best at 77.
I wish my LC9 was like that!
Old May 18, 2018 | 08:52 PM
1994Vmax's Avatar
Since the inception of the internal combustion engine. If it was we should all rock 2.56 gears lol. Running down the highway at some pathetic low rpm does nothing any justice but in a wind tunnel. The only good factory half ton set up is the max tow 3.73s and even then depending on tire choice it's probably too little.
Old May 19, 2018 | 11:47 AM
turboal1's Avatar
Default Rpm
with my 4L60 and 3:73 gears 26" tires
at 70mph = 2400/500 rpm's, I'm going to switch
to 27" tires this summer to drop the RPM'S
a little bit lower. 295x40x18 I need more
rubber on the ground anyway since the eng swap.
Old May 19, 2018 | 12:08 PM
EVandy's Avatar
Registered User
With my current 5.3 and 3.42 the problem I have the most is the gas mileage goes to straight crap over 70 mph and it’s constantly down shifting. I had the truck tuned and it helped a bit but not much. I’m not as concerned about MPG rather it constantly dropping into 5th gear and sometimes 4th. Will the bigger motor by itself solve that problem? Also I’m running stock 20’s with the normal 275/55r20. Wanting to go to 22’s soon though. Probably with 305/40’s or 285/45’s
