which gear lube for eaton?
Old May 20, 2003 | 08:57 PM
KeukaZ71's Avatar
Default which gear lube for eaton?
i know GM's owners manual says one gear lube weight, but i was told not to use that for Eaton Posi. i was told to use 85/140. does that sound right? also, which brand is good? i was told 2 different brands by 2 different people. i won't say what they are until i hear back from a few people. i don't want to bias the results
Old May 20, 2003 | 10:25 PM
Yelo's Avatar
Default Re: which gear lube for eaton?
what does Eaton reccomend ???
Old May 20, 2003 | 11:39 PM
CashDudeHomie's Avatar
I used Slick50 brand 80W-90. I also used a tube of Equatorque posi additive. So far so good here. I wouldn't use the Pennsoil. It says not to use additives with it so it was noisier than usual.
Old May 21, 2003 | 01:43 AM
LS1TECH Sponsor
The only requirement i belive of gear lube is that it is classed GL-5. And one bottle of GM posi additive used. On the 1/2 tons it has a tag for sytethic gear lube requirement, so why not use synthetic gear lube.
Old May 21, 2003 | 03:26 PM
KeukaZ71's Avatar
i haven;t received the Eaton yet, it is in transit. when i called around for prices, the 2 different places i talked to both said to use 85/140, which is non-synthetic stuff. they said even though GM says to use the synthetic, don't use it. i also heard to stay away from pennsoil too. i heard lucas or valvoline is good. what have others with Eaton used for weight and brand?
Old May 21, 2003 | 03:44 PM
Black Blown 02's Avatar
The eaton comes with a card that tells you what lube to use with the posi. Its Gm#1052271 with limited slip additive#1052358. Ive heard of guys clutches slipping with synthetic cause its too slick.
Idryfly5
Sep 2, 2022 08:55 PM
Oobray
Jun 13, 2022 03:38 AM
blownss27
Aug 14, 2020 08:27 AM
jtphelps289
Sep 29, 2015 12:00 PM
Turk55
Sep 11, 2015 11:52 AM
