Gauge Wiring
Old Feb 26, 2007 | 07:29 PM
Blown06's Avatar
8 Second Truck Club
Default Gauge Wiring
Not sure if this is the right forum...
Can I run 1 power wire up the a-pillar for all my gauges or will it be over loaded? If I can should I run an inline fuse, what type/size? Also, were is everyone else getting their 12v key on power source?
I have electronic fuel press, mechanical boost press, AEM wide band. And the lights for each.
Old Feb 27, 2007 | 02:17 PM
FastCrewCab4x4's Avatar
If your just useing the 1 wire to power the gauges and the gauge lights it will be fine, but you'll need 1 more for a ground. I got my keyed power from the fuse box at the side of the dash when you open the door. you can buy a adapter that plugs into the fuse holder that replaces the fuse and has a spade stickin out so you can plug your wire onto it, and you can still plug the fuse into it.
Old Feb 27, 2007 | 04:39 PM
Blown06's Avatar
8 Second Truck Club
Thanks.
Old Feb 27, 2007 | 05:52 PM
nonnieselman's Avatar
yea just a wire to supply power to you gauges and lights, it will work... what size you running?
Texas5.3_1251
Mar 5, 2016 08:10 PM
kalikid06
20
Oct 13, 2015 07:37 AM
kalikid06
Sep 13, 2015 05:48 PM
97gmc
22
Sep 8, 2015 10:56 PM
muncie21
Sep 7, 2015 09:55 PM
