Gaskets/seals for Cam install...
Old Feb 20, 2004 | 08:47 AM
OBXMarine's Avatar
Default Gaskets/seals for Cam install...
Well gents, I'm wrapping up the shopping list for the cam, TC, and Shift Kit install. I figure I'll need a front engine seal, 2 water pump gaskets, 2 valve cover gaskets, and a transmission pan gasket. Am I missing anything? From what I remember the valve cover gaskets aren't necessary and a real PITA to replace.
Also, I'm heading to Advanced Auto parts in a bit. I assume the replacement seals/gaskets they offer are comparable to GM quality. What are your thoughts?
Old Feb 20, 2004 | 09:04 AM
getsome's Avatar
Well it sounds like you have most of it. I assume that you are changing the tranning filter too. It isn't required but the crank bolt is a good idea. Everything else sounds good.
Old Feb 20, 2004 | 09:20 AM
Scream's Avatar
MOOBIES Moderator
YOU HAVE TO GET A CRANK BOLT! They are torque-to-yield and have to be replaced once they've been torqued down.
You really don't need to get the w/p or timing cover gaskets, as they are re-useable. The front oil seal isn't a bad idea if you have some miles on your motor.
OBXMarine's Avatar
Yes, I already planned for the filter. I have the crank bolt in hand. It came with the ASP Pulley kit.
Old Feb 20, 2004 | 09:22 AM
OBXMarine's Avatar
51k or so, not too much, but since I'm in there...
Old Feb 20, 2004 | 09:27 AM
getsome's Avatar
Ya i would put on the little o ring on the oil pickup tube. I didn't after my cam install and had do oil pressure. It is worth the 8 i spent.
Old Feb 20, 2004 | 09:29 AM
mudz5.3's Avatar
OBX, what size cam are you going with?
Old Feb 20, 2004 | 11:05 AM
OBXMarine's Avatar
Thank you! I forgot about that! Good save!!! Do you have a GM part number by chance?
A slightly used 208/216 on a 113 LSA with LS6 Springs. You all may have seen it before.
Old Feb 20, 2004 | 11:08 AM
getsome's Avatar
I am not really for sure but i think it is 12557075. Ya it is a time saver when doing the install so you don't have to do it twice.
Old Feb 20, 2004 | 11:22 AM
FLATOP08's Avatar
The number is 12557752 for the O-ring.
