gaskets, rings, bearings, etc
Old Nov 24, 2009 | 10:32 AM
454navyss's Avatar
Default gaskets, rings, bearings, etc
i almost have everything i need to put my new engine together, where is the best place to buy gaskets, rings and bearings for it though? it is going to be an iron ls1 with 243 heads. i would also like to buy some arp main bolts and connecting rod bolts for a little added assurance, where should i buy them?
i would like it to be around 11:1 compression, do i need to have the heads milled at all, what thickness gasket should i use? i think i can get away with gaskets that are thinner than stock but im not sure.
Old Nov 24, 2009 | 06:05 PM
454navyss's Avatar
doesnt anyone build their own engines on this board?
just kidding, but seriously, where is the best place to get this stuff?
Old Nov 25, 2009 | 05:45 PM
454navyss's Avatar
hmmmm
Old Nov 25, 2009 | 05:55 PM
00ChevyScott's Avatar
Wearin' da big hat
Wal-mart
Old Nov 25, 2009 | 06:18 PM
silveradokidd_4518's Avatar
Texas Speed has the bolts you are looking for
and yes the heads will have to be milled to get the higher compression you are looking for
Old Nov 25, 2009 | 07:48 PM
454navyss's Avatar
stock ls1s have 10.5:1 compression dont they? i guess i should have the heads milled about .010 to get around 11-11.5:1 compression?
Old Nov 25, 2009 | 09:42 PM
53RUSSELL's Avatar
I'm building motor as well. As far I know you can't get arp mian bolts. I looked and couldn't find them. I got bearing thru guys that have crank balance
Old Nov 25, 2009 | 09:51 PM
nlawson6.0's Avatar
i got my multi layer head gaskets for gmpartsdirect
Old Nov 25, 2009 | 10:01 PM
Phantom's Avatar
11 Second Club
i bought my head gaskets and rod bolts from speed inc, bearings from o'reilly auto parts. your stock main bolts should be just fine
Old Nov 26, 2009 | 07:07 AM
budhayes3's Avatar
PT's Slowest Truck
Are the main bolts that go through the side of the block TTY? I thought that I read that on Tech a while back?
