FYI: Lq9 and 4Lo in a 1/2 ton T-case are NOT a match made in heaven
Old Oct 10, 2005 | 06:51 PM
treyZ28's Avatar
Default FYI: Lq9 and 4Lo in a 1/2 ton T-case are NOT a match made in heaven
I've had it for 2 weeks. Had to try 4 Lo. 3/4 throttle dip of the throttle = tires spinning, truck jumping and something breaking. I tapped the throttle.
I figured the cold mud terrains would spin on the cold road before anything snapped. Nope. Rice Crispies!
2wd sounds fine. 4x4 (manual t-case btw) sounds weird. Im thinking i popped a tooth of the ring and pinion.
Old Oct 10, 2005 | 06:58 PM
damn ,, nice truck.anyone konw what lQ9s dyno?
Old Oct 11, 2005 | 07:12 AM
white1's Avatar
Damn, glad to hear about that before I tried with a cammes/stalled LQ4 in my RC. Maybe it will be safe in the RCSB
Old Oct 11, 2005 | 09:35 AM
Nick™'s Avatar
don't even try it, once this transmission goes up I don't plan on being under your truck again for a little while...
<- white1 after he tries it
Old Oct 11, 2005 | 09:52 AM
white1's Avatar
He said it still works fine in 2wd right?? I'll just have to use Nicks towing service for Nicks pulling out the mud hole service 4 wheel peel = sweet
Old Oct 11, 2005 | 12:03 PM
treyZ28's Avatar
I'm really hoping it wasn't something serious... I'm not looking forward to this.
Old Oct 11, 2005 | 12:57 PM
BigTex's Avatar
Is your warranty expired?
Old Oct 11, 2005 | 01:07 PM
StrokerAce03's Avatar
Don't think he'd have one after the lq9/4L65e swap. Hope you get it fixed man, maybe it isn't too bad.
Old Oct 11, 2005 | 01:15 PM
BigTex's Avatar
Unless he tells someone at the service department, no one would ever know. Physically both the engine and trans are externally identical to the stock motor and trans. No one would ever see the 6.0 casting on the block and there are no marks identifying the transmission.
Old Oct 11, 2005 | 01:32 PM
TXsilverado's Avatar
its worth a try
