Funky idle.....and other strange issues....
Old Nov 30, 2003 | 09:09 PM
Yelo's Avatar
Default Funky idle.....and other strange issues....
I'm having a strange idle issue....when I start the truck sometimes it will start up and idle just fine, other times it will start hard and not want to idle worth a damn. I figure it's the IAC Valve (bought it but haven't changed it yet...no returns on used electrical parts...if this isn't the problem I want to be able to retun the part cause it was $100)
I am also having a really wierd electrical issue...when I drive at night my headlights will "flicker", they won't go completely out or anything but they will dim for just like 1/2 second or so....at first I thought I was seeing things until my friend asked me if my headlight were having seizures. It's only the headlights...no other lights do it EVER and the amp guage doesn't move so I don't think it's the alternator, it it possible it's a bad ground to the headlight circuit ???
anybody got any ideas ???
Old Nov 30, 2003 | 09:15 PM
Some times, cleaning out the throttle body helps idle quite a bit. On the headlights, follow the wires and check for any splices or melt marks.
Old Nov 30, 2003 | 09:22 PM
Yelo's Avatar
I tried cleaning out the TB...I even took out the IAC and cleaned it (pretty nasty)...it seemed to help but it is still doing it a little
Old Nov 30, 2003 | 09:52 PM
jlwz71's Avatar
Pull the vacuum line off of the fuel pressure regulator after it sits overnite. If any fuel comes out of the vacuum line time for a new fuel regulator. Happened to me.
Old Nov 30, 2003 | 09:53 PM
BlownChevy's Avatar
blownerator
25 Year Member
Exactly what I was going to suggest!
Old Nov 30, 2003 | 09:55 PM
XLR8NSS's Avatar
Adkoonerstrator
fuel pressure regulator GM part# - 17113678 $9X dollars if I remember that mistake right.
Old Nov 30, 2003 | 09:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by XLR8NSS
regulator kit GM part# - 17113678 $9X dollars if I remember that mistake right.
Thats the one! I am pretty sure that the problem.....it was when I had the same staring issues.
Old Nov 30, 2003 | 10:00 PM
Yelo's Avatar
sheesh...another $90 part
I will check out the line in the morning......just to be sure...where exactly is the FP regulator ?? (I know it's on the fuel rails but where exactly)
Old Nov 30, 2003 | 10:03 PM
BlownChevy's Avatar
blownerator
25 Year Member
I think you can get just the regulator for less.
Its on the driver side fuel rail, goldish in color.
Old Nov 30, 2003 | 10:04 PM
XLR8NSS's Avatar
Adkoonerstrator
It's the half dome looking thing clipped on the driverside fuel rail with the little vacuum line running to the top of it. Know what I'm talking about?
