Fueling Upgrade
Old Apr 22, 2011 | 02:45 PM
  #51
Atomic's Avatar
I have a gauge for that
I know this thread is old, but why, Dr.X, did you see a need to keep the OE feed line?
Old Apr 22, 2011 | 04:00 PM
  #52
DrX's Avatar
DrX
I didn't. I ran -10 from the pumps, Y-d to -8 at the rails, and -8 (IIRC) back to the surge tank. Before the twin blowers and surge tank setup, I used the OE feed as a return line.
Old Apr 22, 2011 | 04:07 PM
  #53
Atomic's Avatar
So you didnt end up using the green line from the surge tank to the Y with the check valve on it?
What pressure did you set the regulator control the surge tank from the main tank?
Old Apr 22, 2011 | 06:21 PM
  #54
DrX's Avatar
DrX
Everything is connected exactly as in the drawing, but the hose lengths are not in proportion to those in the sketch. That first Y you are referring to is the blue block immediately forward of the pump in the photo. Everything encompassed by the square on the sketch is right beside the surge tank. You can also see the rear regulator in the photo. It is not mounted right on the tank as per the sketch. I have removed the OE fuel line. It is replaced by a braided teflon line from the OE pump to the rear regulator. I did clean up the mess of hoses you see in the photo though. I still intend to do some more rearranging back there.
I removed the reg from the OE fuel module and blocked off the port for it. The rear reg is set to factory fuel pressure. I think the front is set to 68 or 70 psi, so it is essentially closed until the Magnafuel kicks in causing the waste from the rear FPR to dump into the surge tank. You could actually run somewhat smaller injectors with this setup because it is a dual pressure system.
Edit: You could do away with the rear reg. I'm not sure how that would affect the factory pump and intank components though. There is a pressure relief port on the OE pumps. Maybe wire it to shut down when the big pump kicks in. This could be a safety feature as well, because if the big pump should fail, there would be no fuel at all and therefore no chance of running lean because only the OE pump was running at WOT.
The bungs on the surge tank are actually all at the front near the top, not on the top of the tank as in the drawing (I just cut/pasted the tank from somewhere).
Old Apr 24, 2011 | 02:14 PM
  #55
DrX's Avatar
DrX
A few new pics. I cut out the spare tire support to tuck the tank up higher.
Old Feb 8, 2012 | 04:06 AM
  #56
caddy03pimpin's Avatar
Good info here
Rafe19
Oct 18, 2016 12:27 AM
Wareagle23
Aug 15, 2015 06:55 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
