fuel rail spacers?
Old Mar 28, 2008 | 10:26 PM
da_vato's Avatar
Default fuel rail spacers?
Im bout to put on some 42lb injectors on my 04 5.3. Is there a special spacer to use? or do I just stack washers? I will avoid the "jerry rigged" look at all cost no matter how minute.
Old Mar 28, 2008 | 10:34 PM
quicksilverado's Avatar
If you have the multec IIs you will not need spacers. If you have the ones that fit the f-body you can get some metal tubing from Ace Haedware and cut it down to the correct length.
Old Mar 28, 2008 | 10:57 PM
da_vato's Avatar
I know I aint got multec II's cause I had to get some different connectors (EV1s). what size of tubing? I would like to have everything prepped as much as possible for install.
Old Mar 28, 2008 | 11:01 PM
Derek @ EDO's Avatar
FormerVendor
i believe 1/2"
Banned
I Do Stacked Washers With Black Tape And They Look Good
Old Mar 28, 2008 | 11:13 PM
bluecajun5.3's Avatar
11 Second Truck Club
what works good is if you have the studs for the intake where the throttle body bolts up.
Old Mar 29, 2008 | 11:10 AM
Stoichiometric's Avatar
I ended up using a 3/4" long aluminum tubing. You have some room to play with for the spacing, the injectors don't need to be pre-loaded down into the manifold. As long as both o-rings are in the bores you are fine.
The_W
Aug 15, 2015 08:07 AM
Aboss
Aug 11, 2015 09:05 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
GMCtrk
Jul 17, 2015 06:39 PM
