Fuel Pump Question
Old Feb 3, 2010 | 04:13 PM
exodus's Avatar
Default Fuel Pump Question
I am working on the project in my sig, and am at the point to where I am going to swap out the in tank fuel pump to a better unit to supply this Magna Charged motor. I have a question that some of you may be able to answer. I have 2 different pumps, and am not sure which of the two is the better one to run. The two that I have are the AC Delco #EP381 which carries a GM part# of 25163473, and the Granatelli Motorsports GM722-2 which I know is a 98-02 F body 255LPH in tank pump that I believe will work on my truck as well. So with my setup which is the better of the two???
Old Feb 3, 2010 | 06:54 PM
eallanboggs's Avatar
You can do a 30 second volume test. You can also do a pressure test to compare the pressure, but you'll have to rig up a schrader valve. Once you know pressure AND volume you can decide for yourself.
Old Feb 4, 2010 | 12:03 PM
exodus's Avatar
dont really have the recources or the time for that right now...otherwise I would. Was hoping someone here would know.
Old Feb 6, 2010 | 11:09 AM
exodus's Avatar
Bump...any info here???
Old Feb 6, 2010 | 11:37 AM
budhayes3's Avatar
PT's Slowest Truck
The Granatelli may just be a repackaged Walboro, which is a favorite 255 pump around here. With the Manacharger, I'd think that the 255 would be better...I think that's what a lot of guys run with their superchargers but I'm not sure. I know that many guys run the factory pump along with a high volume inline pump, which I believe is a 255.
If any of this info is incorrect, at least I was able to bump your thread to the top for you
Old Feb 6, 2010 | 06:49 PM
exodus's Avatar
Thanks for the info and the bump.
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
slowlsx
Aug 13, 2015 08:28 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
