Fuel Pump Problem
Old Feb 6, 2005 | 12:03 PM
Default Fuel Pump Problem
the fuel pump in my truck started making a loud whining noise. how screwed am I? Please help.
Old Feb 6, 2005 | 12:53 PM
greentahoe's Avatar
Mine has been doing this on and off as well. Maybe its time to replace it. What do they run? How hard are they to replace? I did a search and it seems this is pretty common and has been discussed many times. The consensus is that our trucks have noisy fuel pumps.
Old Feb 6, 2005 | 12:59 PM
okay just did this the other day on my rcsb, although mine wasn't whinning or making any strange noises i was geting some surging and it took forever to start the truck. i know this will be different for greentahoe becuase he probably will have to drop the tank. What i did was took off the bed, once i got the bed lifted off with a couple of buddies the swap took about 10 min tops. just disconect the lines and pop the new one in, no sweat. My bed was real easy to take off, i decdied to do it this was becuase i had about a half tank of gas. Just unbolte the 8 bolts that hold the bed on and unplug to plugs right near the bumper and unbolt the filler neck holder behind the fuel door. i got the pump off a memeber on here for 200 bucks, this included the pump and the sender, i got quoted by the dealer a price of 400 for the pump and 80 for the sender part, YIKES!
Old Feb 6, 2005 | 02:30 PM
storm5.3's Avatar
13 Second Truck Club
If no problems w/ the way it runs then forget about it. Mine started making that noise at around 50-60k and didn't go out till over 150k. Just listen to other GM trucks and suburbans and you'll start noticing the same noise. I like you was concerned but everyone I talked to said those pumps are good for well over 100K and they were right in my case...Zed
P.S. By the way I had over 3500 hrs. on that pump when I replaced it.
slowlsx
Aug 13, 2015 08:28 PM
roprisiu
Aug 9, 2015 10:47 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
