fuel pump flow?
Old Nov 21, 2003 | 08:53 PM
L-EATER's Avatar
11 Second Truck Club
Question fuel pump flow?
Does anybody know the actual flow rating in liters per hour of gallons per minute of the stock truck fuel pump? I want to put in a bigger pump but I kinda need to know what I have to start with. Couldn't find anything on a search.
Old Nov 21, 2003 | 09:09 PM
ranwalk's Avatar
It might be best to add an inline pump. I dont think anyone offers a performance pump for the trucks yet. You can use a performance pump for an f-body but I have heard the pick up isnt the same and if you get down to 1/8 tank of gas it will bog under heavy accell.
Old Nov 21, 2003 | 09:26 PM
L-EATER's Avatar
My experiences with inlines are that they are noisy and I don't want that. I already acquired another pickup/pump assembly and I am prepared to modificate whatever is necessary to install a hipo in tank pump. I am thinking about one of the big Walbros for a Mustang. I currently run a 'Stang 255/lph in my LT1 powered 94 work truck.
Old Nov 21, 2003 | 09:46 PM
GMC SKI's Avatar
DO you run an inline Pump ?
I'm going with the high pressure walboro inline 340
I also going to have my intak pump modified by racetronix to a walbro intank
should be good for upto 700rwhp with my new rails and fuel lines
Old Nov 21, 2003 | 10:21 PM
Flyer's Avatar
The inline pump that came with my Radix kit wasn't to bad as far as noise went. Only time it was noticable is when I had the small o-ring on the fuel pressure regulator mess up and it was constantly pumping full bore. Even then it wasnt to bad.
Old Nov 21, 2003 | 10:51 PM
silent1's Avatar
I installed a 255l/ph in my truck, not that bad of an install. Wish I would've taken some pics. I found some pics in the fueling section, try a search.
Old Nov 22, 2003 | 12:22 AM
parish8's Avatar
single digit dreamer
i had the walbro gss340(255lph) inline, it wasn't loud at all, the only time i could hear it was when i was in a drive thru or something like that and even then it wasn't loud. no louder than most stock fords i have heard. the fbody guys say a stock pump is good for 450rwhp and with this inline added in 600rwhp. i would have to say that prety much matches what i saw.
if you dont plan on going over 600rwhp then it is a very simple and cheap way to go. i would love to see someone work out a max effort fuel system though, something simple and very effective that i could copy.
Old Nov 22, 2003 | 06:39 AM
GMC SKI's Avatar
I should have one for you real soon
I'm going to end up using the stock feed line as the return line. Then I'm going to run a new feedline from the tank to the new intank pump
should be good for some real power and not be too expensive to do
I also have new fuel rails coming and reg
I'll post some pictures when i get all the gear
GXPJAY
Feb 13, 2022 08:15 AM
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
