Fuel pump dying or...?
2003 Silverado SS w/ P-1SC stock 4" pully. Truck has new NGK TR6 plugs about 300 miles ago. Just put some 60lb Siemens Deka injectors in about 50 miles ago. Everything was running great, came back from flying out west for a few days and starting to feel some problems. Everything seems fine when driving normally, but at WOT and RPM's above 3500 or so the engine seems to chug/sputter. I replaced the fuel filter and it didn't seem to make a difference. Do you think this is the stock fuel pump on it's way out? (VROOOOOOOOOOOOOOOOOOOM DUH DUH DUH DUH DUH DUH ---rhythmic)
I should preface this by saying that is has been throwing lean codes since I got it (171, 174) and one time it threw a couple O2 sensor codes. Performance is not affected by the codes. I don't know if the lean codes and the other issue are in any way related at all.
Thanks ahead of time.
I see that they sell some locally. I read that you just have to hook them up to the Schroeder valve on the crossover to the fuel rail. Will I be able to tell anything if it isn't under load or will I have to route something into the cab?
11 Second Club
I'm pretty sure the fuel pump is supposed to be upgraded when you installed a SC. When you recently upgraded the injectors, was it retuned? It should have been of course. A wide band tells you what your air/fuel ratio is running at, which is critical with power adders. Lean codes are not supposed to happen if all is well, you need figure to this out immediately.
It is definitely tuned for the new injectors. The SC was installed before I got it, but it seems like the previous owner pretty much bought the kit and threw it in there without doing any other modifications so I'm still trying to figure it out.
