fuel pump
Old Mar 31, 2007 | 09:55 PM
kingots2004's Avatar
Default fuel pump
i installed the walbro pump from texas speed we removed the bed and got it done in 1.5 hours it would have been quicker but my dremel tool went dead.the bed is really easy to remove 8 bolts and 2 connectors right behind the bumper plus the 3 little bolts that hold the filler neck on
Old Apr 1, 2007 | 06:17 PM
Onyx 02's Avatar
I'm in need of replacing my fuel pump this week, mine took a huge $hit!! So, any help/advice you can give me will be much appreciated. Where did you buy your Walbro? What was the dremel tool needed for? Are there many modifications to do, to work with the stock connectors?
Old Apr 1, 2007 | 08:26 PM
DamnYankee's Avatar
formerly Moze (2/24/2012)
Contact Nelson Performance or TRT Performance. They can both get you one ...
Old Apr 1, 2007 | 09:00 PM
Quik's Avatar
5 year bitches!
you dotn need to do any modding to the pump housing. just pull it apart drop new pump in and wire the new plug up...thats all its to it
Old Apr 2, 2007 | 05:02 PM
i bought my pump from texas speed i had to mod the bottom of the pump bucket to get the pump low enough to get the new screen on the bottom.there is a plastic piece that sticks up from the bottom about 1.5 inches.you have to remove that and zip tie the pump to the housing plus in stall the supplied connector that fits the pump the plug is different.its very easy.tips and tricks has pictures under the gm motor section ryhno79 posted.only diff i did was remove the bed it was a lot quicker.good luck
Old Apr 2, 2007 | 07:37 PM
Quik's Avatar
5 year bitches!
you ddint need to cut that hole. the pumps ive done use a filter on the pump and still use the basket's filter so its double filter. and for some to say it has to be sumerged in fuel. its in fuel already and gets plenty of fuel
Old Apr 2, 2007 | 07:49 PM
Onyx 02's Avatar
Thanks for the info.
Old Apr 2, 2007 | 07:54 PM
speedy02's Avatar
Thats going to be my next mod! I thank my stock one is maxed out.
Old Apr 2, 2007 | 10:05 PM
Rhino79's Avatar
9 Second Club
The Walbro pumps I've seen are not long enough on the inlet side to put the filter on. They are also more narrow than the stock pump and don't fit snug like the stocker.
Old Apr 3, 2007 | 10:26 AM
Quik's Avatar
5 year bitches!
thats odd honestly. my pump sits nicely in there. i put the black rubber around it and my filter sits right on the pump at the bottom of the basket.
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
