fuel pressure regulator location
Old Aug 30, 2006 | 10:25 PM
silver-bullet's Avatar
Default fuel pressure regulator location
well i figured out what i need hopefully. i am getting a new fpr and am not sure where it is or how to replace it. any tips/tricks?
Old Aug 30, 2006 | 10:38 PM
sroach20's Avatar
driver side fuel rail on the trucks.
Old Aug 30, 2006 | 10:40 PM
are they easy to replace. am i gonna get blasted w/ fuel or anything?
Old Aug 30, 2006 | 10:46 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Yes! Have a towel on standby and just be ready for it
I pulled my FPR yesterday. The front half came out and sprayed me a little then I pulled the filter with the attached small O ring and got another shower of 93 octane . If you are going to change the fuel filter as well, crack that loose first, to relieve the line pressure.
Old Aug 30, 2006 | 10:49 PM
sroach20's Avatar
you just pull the vacuum tube, take off the little metal clamp thingamojobber, and it comes right out. like1slowhoe said use the towel. it should take 3 minutes.
Old Aug 30, 2006 | 10:58 PM
thanks guys
Old Aug 31, 2006 | 05:53 PM
I was told to take off the gas filler cap and release pressure that way
Old Aug 31, 2006 | 06:17 PM
1SlowHoe's Avatar
That might work. I never tried it
sroach20's Avatar
itll still have fuel in the rails.
Old Aug 31, 2006 | 07:02 PM
True, like I said I was told that and somebody is gonna have to be a guinnea pig. It might lessen the spray?
