Fuel Pressure Question
Old Nov 8, 2004 | 08:26 PM
BlownAlaskan's Avatar
Default Fuel Pressure Question
According to my autometer electric guage, I have been around 52psi at idle for a long time. Fuel filter is reasonably new. Yesterday after I swapped in the 57's I noticed the guage now reads about 50psi at idle. Is this normal? I thought our fuel pressure was to be around 58psi at idle.
Can these factory regulators be adjusted? Do you think my guage is reading wrong?
Old Nov 8, 2004 | 08:38 PM
Chevmann99's Avatar
Mines about 50-52 at idle and goes up to about 60 when I get on the gas.
Old Nov 8, 2004 | 09:20 PM
parish8's Avatar
single digit dreamer
your fine. when people talk about "base" fuel presure that is under no vacume or boost. when under a vacume the regulator reduces the presure and when under boost it increses the presure. if you pull the vacume line to the regulator you will see your base presure and that is probably around 58psi.
the regulator tries to keep a 58psi diference between the 2 side of the injector. i see about 55 at idle but i have low vacume and close to 75psi at max boost.
Old Nov 8, 2004 | 09:58 PM
OK. That makes sense.
wrb002
Aug 31, 2015 12:00 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
