Fuel Pressure Guage Installation.....
Old Mar 13, 2005 | 12:55 PM
  #21
wkdivr's Avatar
Originally Posted by LAUST
will this adapter work?
Earl's ''AN to NPT'' Adapter Fittings
361-981604 -04AN to 1/8''NPT
Or is it something like this?
http://store1.yimg.com/I/whitespitstop_1834_5488296
I think you need a female -4an to male 1/8 npt. Then you need a 1/8npt bushing, female on both ends. I'm not sure of the part numbers.
Old Mar 13, 2005 | 02:45 PM
  #22
CAMMIN03''s Avatar
Banned
Ok so Im going to need a female to adapt to the FUel rail and then another female to adpat it to the sending unit????
Old Mar 13, 2005 | 03:41 PM
  #23
wkdivr's Avatar
One end has a female -4AN, the other end has a male 1/8 NPT. Then you need a 1/8 NPT bushing, it has a female 1/8 NPT threads on each end. Black Yukon has a good shot of it.
Old Apr 17, 2005 | 05:14 PM
  #24
Someone told me this is all I need? guess it's bad info?
Autometer Fuel Rail Adapter
1/16" NPT Male to 1/8" NPT Female adapter for fuel rail. For use with Electric Fuel Pressure gauges. #3280
I am trying to install the sender today. I would like to do it without taking the valve stem out. Is this possible with the 4an fitting. Please help!
Old Apr 17, 2005 | 06:33 PM
  #25
CAMMIN03''s Avatar
Banned
No you have to take the valve off to get pressure to the unit.... You could tape it in the fuel rail I guess..... But I mean it takes about 30seconds to get the valve out... the tool can be bought for about 2.00
And get the Earl Fittings from SUmmit
Old Apr 17, 2005 | 07:45 PM
  #26
black_yukon's Avatar
Just take it out! The tool can be had for less than $2.00 at pepboys, but if you want to be real econimical, you could use needle nose pliers.
Old Apr 17, 2005 | 10:11 PM
  #27
I have the tool alright. I was hoping that This could be a quick disconnect setup just like the test gauges which depress the valve stem as you thread the fitting on. What do you thing?
Old Apr 17, 2005 | 11:34 PM
  #28
I've had mine installed for close to 3 years and never had a need to disconnect it. Even if you did need to disconnect it, it would take about 5 minutes to unscrew the fittings and put the valve back in.
Old Apr 18, 2005 | 12:13 AM
  #29
moregrip's Avatar
what a rush!
I got half my installation done today, I mounted up a remote fuel pessure sender and a remote boost sender for a couple Nordskog gauges I have. It ended up looking pretty nice. I had some stainless steal braided lines made up with the appropriate AN fittings. The lines are a little overkill as they are rated for 3000psi, but they are very high quality -4 shizzles. Used permatex high temp pipe sealent on all the NPT fittings.
Thats about it, no leaks, everything is tidy and clean
Old Apr 18, 2005 | 05:30 PM
  #30
wkdivr's Avatar
Exclamation
Have any pics? That's what I'm in the middle of. Sounds like electric fuel pressure, and mechanical boost/vac gauge, right? Where did you mount the fuel pressure sender?
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
