Fuel pressure guage hookup question
I have a Radix so I will be looking to tap off of where the schrader valve is.
Did some reseach and found that you really have to get a bunch of "T" s/adapters/unions/couplers to meet up with the electric sender.
I don't expect to have alot of room and would like to keep the vavle so can I add a 4AN female hose off the fuel rail and bring that around to near the fuse box (where there is more room) to make my adapters/"Ts"?
Originally Posted by 02BlueStepside
Wait for some more replies. I was under the impression that for a radix it was already a 1/8ntp fitting. For stock trucks/fuel rails, you only need two fittings, a reducer and coupler.
Originally Posted by wkdivr
Where the schrader valve taps into the fuel rail, it's 1/8 npt threads. The cap is -4AN.
If you take the schrader valve out of the rail, the sender will screw right in.
if that works then all I need is a 1/8 T to put the schrader valve back in!?
I see all these post of these contraptions of fittings all off the rails and stuff.
Would be awesome if all I have to do is take the fitting out and insert the sender.
Will the sender fit physically? I know it's a tight space.
