Fuel Pressure Gauge....
Old Mar 6, 2003 | 05:27 PM
racerfoo's Avatar
Default Fuel Pressure Gauge....
What is the importance of a fuel pressure gauge and how do you read it? I am running nitrous....do i need this gauge?
Old Mar 6, 2003 | 06:43 PM
parish8's Avatar
single digit dreamer
Default Re: Fuel Pressure Gauge....
is your kit wet or dry? if you try to run larger than a 125shot with a wet kit i would have one. it should read around 58psi at wot but will drop a little at idle. you would be watching for it to dip at the top of each gear, if the presure falls during a wot blast it only takes a second for it to go lean and break a piston.
Old Mar 6, 2003 | 09:50 PM
StreetSweepa's Avatar
He's running a 100 shot dry kit.
<small>[ March 06, 2003, 09:51 PM: Message edited by: StreetSweepa ]</small>
Old Mar 7, 2003 | 12:00 AM
GoldenVelvet's Avatar
If your N2O kit is worth its salt it will have a fuel pressure shut off. If the fuel pressure is too low the N2O wont engage. If your kit does not have one they are cheap and easy to add.
Old Mar 7, 2003 | 04:12 PM
parish8's Avatar
i wouldn't spend the money on a gauge if your going to stay at a 100 dryshot. prety sure your injectors will run out before your pump. if you decide to push it you might want to look into atap and a fuel presure gauge.
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
