Fuel in Oil
I have n 06 chevy 1500 with a 6.0. I noticed my fuel mileage has went down a bit in the last 2 tanks, well I check my oil every so many miles and last time I checked it was 1500 miles ago and it was full. Today I checked it and it was 2 quarts or better over full. So I drained and checked it and sure enough it had over 8 quarts of oil came out it. I put a fuel pressure guage on it and it ran at about 55 to 57#'s and turned it off and it held pressure. It only lost a few lbs after about 10 minutes of it sitting. So I pulled the fuel rails to check injectors again, turned key on and off and injectors are dry no leakage at all. I figure all it can be is pressure regulator but how do u check to make sure?
How do I change this text
Look some where else. it sounds as if your fuel system is working ok. A few pounds drop is fine after shut down. Does the engine get as hot as it should? a stuck thermostat will cause the same issues. What do you have for mods and tuning???
Does the oil smell like fuel or sweet like coolant?
Actually, if it was coolant, the oil would have been milky when you drained it. I'm sure you would have noticed that. Does the truck have any starting issues?
