Fuel/Air Delivery experts needed
Old Jan 19, 2010 | 07:07 PM
BIRCHZ71's Avatar
Default Fuel/Air Delivery experts needed
Need some help here. Truck keeps going to sleep on me.
Here's the facts.
I changed converters from a 9.5" 3000 stall to a 12" 2500 designed for towing. Not only that I went from a 31" tire to almost a 34". Pretty much turned my z71 from a street truck back into a off road truck.
Here is my problem.
Every time I go through a gear or two at WOT and then slow down for whatever reason, the truck wants to die. During regular driving I don't seem to have this problem, just after a hard run. Today when this happen I pulled over and listened to my truck dropping down to like 400 rpm's loping like it was about to die. Also, the engine light was blinking? The smell of gas was unbearable out of the exhaust. I stuck my head under the rear bumber and almost suffocated. (running rich I'm assuming") So should I be getting Wheatley to re-tune since I made these changes? He did a live 93 tune with the old setup.
I should also add that I just installed a new K&N filter and have already cleaned the MAF twice since. That oily *** filter might be creating a problem too.
By the way its an 04 z71 with all the bolt-ons.
Thanks in advance gentlemen.
Birch
Old Jan 20, 2010 | 09:22 AM
thunder550's Avatar
High on diesel fumes
Blinking engine light is a misfire. I'd start by checking plugs and wires first, then injectors. I think you have a mechanical problem that needs to be addressed first, then maybe a tuning issue after that depending on what the results are.
Old Jan 20, 2010 | 10:30 AM
BIRCHZ71's Avatar
OK i'll start there, but tell me how much since this makes.....when i restart the truck it is fine. Which makes me think it is more electrical. And like I said before....it drives great when it stays below 4500 rpms.
Old Jan 20, 2010 | 02:51 PM
Mrgoodwrench3's Avatar
Blinking Check Engine Light is usually a indication of a severe rich condition. There is so mush fuel that it is damaging the catalytic converters. How did you clean the MAF sensor?
Old Jan 20, 2010 | 02:57 PM
BIRCHZ71's Avatar
ok its definately running rich....but only ater I go heavy throttle then slow down. If i restart the truck it seems to be fine. Just used MAF sensor cleaner. I think its made by CRC or something like that. Simple to use. Need some help here guys. Just happend again about 10 minutes ago.
Old Jan 20, 2010 | 03:11 PM
BIRCHZ71's Avatar
also, cat converters are non existent on my truck....long tubes/ORY
Old Jan 20, 2010 | 03:15 PM
Wheatley's Avatar
Truck Sponsor
Can't see it being a tune issue when it has been fine all this time.If the SES light is blinking,then you have a missfire.
Check plugs,wires and even could be a coil but I doubt it,but you never know.
Missfires will cause these symptoms
Old Jan 20, 2010 | 03:19 PM
BIRCHZ71's Avatar
ya im with you charlie.....i dont see it being the tune either. To me it's just weird how it only does this after I romp on it. And the smell of gas is truely unberable.
Old Jan 20, 2010 | 03:41 PM
BIRCHZ71's Avatar
wheatley, you have a pm.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
