Fuel
I ordered new injectors on-line in which I ordered Delphi 253020288 with 4 holes. I received Delphi 171145031M with two holes. The injectors are for a 2000 GMC sierra 2500 with a 6.0 litre engine and 4WD. The pickup is a three door LS model. With the Delphi 171145031M work or should I send it back and try to locate the type that was previously in the truck.
Can you link what you bought because when I search those part numbers they do not come up with anything.
The numbers are too long from the looks of it, you must have added in a number or two on both.
In the end though, the injectors you bought must be 25lb/hr injectors to match the factory injectors in the truck.
marineusmc4
Oct 17, 2016 09:33 PM
