Change knock sensors while I'm in the area?
Ok, I pulled my mainfold off to replace the gaskets. Now that I'm in there, I noticed that maybe my knock sensors are causing some of my issues? In the cab when I put load on the engine in 4th I can actually hear air whistling....which means air leak. Also, is there supposed to be some sort of gasket where that thing goes into the top of the intake in the front (the thing that wiggles around even if the bolt is tight)?? Also noticed I guess Im burning a lot more oil than I thought since my head ports were full of oil and they've only been on since the spring.
Wearin' da big hat
Those are just the rubber caps over the knock sensors. They're going to be dirty. I'd clean up the area for sure and build an RTV dam like a lot of people suggest.
Also I'd look into changing your PCV valve and installing a catch can, looks like its pulling a lot of oil up through the PCV system.
