Ford Racing 42lb Injectors for 5.3 Chevy
Old Nov 9, 2005 | 03:14 PM
CoonToot's Avatar
Originally Posted by 1SlowHoe
Those look like a much better alternative even at $80 a set.
Old Nov 9, 2005 | 03:37 PM
kbracing96's Avatar
But those are for a flex fuel harness, right 1SlowHoe? They are different from a regular truck harness.
Old Nov 9, 2005 | 03:45 PM
XLR8NSS's Avatar
Adkoonerstrator
Yeah, that other connector doesn't look like the multec II connector. AFAIK there is no seperate connector end available to make an adapter like that for the multec II injector.
TurboAV - Here is a writeup I did on how to convert over to bosch style injector(Ford SVO 42# included). It's not hard but, it is kinda time consuming. Once you switch over to this style injector your choice for injectors opens up a ton.
http://hauln.net/LS1Tech/truck/fuel_injector/index.html
Old Nov 9, 2005 | 04:42 PM
CoonToot's Avatar
CoonToot--You got the part number for the connecters?
MSD-2400
Summit Catalog Page
Old Nov 9, 2005 | 05:35 PM
1SlowHoe's Avatar
Destroyer of Transmissions
That adapter does fit my flex fuel clip BUT it was designed for Corvettes if I remember right. It just happened to fit my clip as well. I have not seen a vette clip to verify they are the same. Those are locally manufactured at a shop close by me. I bet if you guys could find me the part number to your clips, the guy could make adapters to go from standard LS1/Truck clips to the Ford injectors. I can at least ask. Anybody actually want some?
Old Nov 9, 2005 | 05:44 PM
1SlowHoe's Avatar
I have had MANY issues with my stock clips coming loose and causing misfires. If these adapters don't work flawlessly, I'm cutting the wires and grabbing a solder gun. I'll let you know after I get it running
Old Nov 9, 2005 | 06:17 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by SSlow 4.8
arent the 8.1L injectors rated at 42lbs?
I believe that the 8.1 marine injectors are 42lb/hr and the 8.1 gas injectors are 31lb/hr
Old Nov 9, 2005 | 06:26 PM
XLR8NSS's Avatar
Adkoonerstrator
I believe Harlan has looked for them before from his connector source and there is no such seperate connector available.
Old Nov 9, 2005 | 11:07 PM
PappyDan's Avatar
Tribe Shaman
get the gun out and burn away, i did and feel better about the connection,
it is more solid now then it was before.
Old Nov 9, 2005 | 11:59 PM
TurboAv's Avatar
Thanks for the help.
