Forced induction guys.....
Old Apr 27, 2005 | 05:25 PM
12sec.5.3's Avatar
Default Forced induction guys.....
What kind of forced induction are you running and how much boost? Also, what compression if you're running a built bottom end? Thanks.
Old Apr 27, 2005 | 05:50 PM
greentahoe's Avatar
Still havent made up your mind You are definately going about it the right way. Ive already told you what Im running...... well, sitting in the garage . What are you looking for? That will help us give you some informed suggestions.
Old Apr 27, 2005 | 06:20 PM
14 Second Truck Club
D1 Procharger, 11 psi, stock bottom. Pulls like hell after 3k rpm. With a stall this thing would be a beast.
Old Apr 27, 2005 | 06:58 PM
litreddevil's Avatar
Banned
Whats wrong buddy don't like the new times with new set up.
Old Apr 27, 2005 | 07:44 PM
Procharger p1sc. 15 pounds of boost on the stock 4.8. Once the little fella gives up, I have a forged bottom end 6.0 ( 9:1 compression) just waiting.
Old Apr 27, 2005 | 08:39 PM
BMDMAX's Avatar
Turbo, 37.5 pounds of boost, 17.5:1 compression ratio on the stock bottom end.
Old Apr 27, 2005 | 08:42 PM
bud8fan's Avatar
8 lbs on stock bottom 6.0...
Old Apr 27, 2005 | 09:23 PM
12sec.5.3's Avatar
Looking to maybe swap the pistons in a 6.0 to make 9:1 compression. Leave the rest stock,(except for rod bolts) then perhaps a p1sc with custom blower cam. About how much boost should I run and what kind of power can I expect? I'm new to the Forced Induction.
Randy- I expected to to slow down a bit going from the PI to the tt3000, but it drives better. I rather it like that. I'll be different than everyone around NPR. In a good way!!
Old Apr 27, 2005 | 09:42 PM
Black Blown 02's Avatar
I'd go with the D1 if I were you. I'm running a P1 with a 3.4" pulley(12psi on a stock cam 5.3) I can't go with a smaller pulley because there's no smaller belts avaliable. The D1 will give you more room to grow with your setup.
Old Apr 27, 2005 | 10:45 PM
jcfreak's Avatar
10psi on stock bottom end.
