Flow Masters
Originally Posted by TrickyTransAm
Ive got the Super 40 series side exit "SuperTruck" exhaust on mine.
It sounds mean as all hell, but be ready for the lag in power.
I can only get brute force out of my truck now when I floor it.
My gas mileage went from around 18 to about 10-12.
My 96 TA was the same when I replaced the stocker with a flowmaster. Lost almost all low end power, and to get it to move out, always had to get into the gas.
Saving my pennies to afford a tune to offset my troubles.
Nelson had indicated it was an ECM issue that needed to be tuned out.
You might have to do the same for it to run decently and to gain any performance from it. (Plus to save your butt at the gas pump)
IMO, get whatever YOU want. One of these days I'll get a cutout and do some track testing to see what the Flowmaster is costing me performance wise. It might be nothing, it might be a couple tenths but I won't pretend to know without any data to back it up. Honestly even if I'm losing a couple horsepower I don't care that much, nothing else has the sound I like so far.
Originally Posted by Frito Bandito
I have the same catback on my truck and love it. I didn't notice any loss in power or gas mileage when I still had the stock tune, though. It sounded great when the truck was stock and sounds amazing with the LTs and ORY. .
My truck is wierd. Its ultra sensitive to any swaps/changes I make.
I tried doing the backyard mechanic removal of the resonator on the intake, that lots of guys do... my truck wouldnt even go down the road. Lost ALL accelleration, horrible vibration howl that shook the gas pedal.
After the GM garage got their hands on it for the wheel sensor recall, they said they updated the PCM, and its been a quirky dog ever since.
The only thing I guess, if your going to go with Flo's, is make sure if you or whoever installs them, DONT weld on the case!
I also took spraycan high temp exhaust header paint, and coated all of my joints and welds on the outside. It helps to slow the rot down a little bit.
after my cam install i replaced my flowmaster with a magnaflow. ive always had flowmasters because of the great sound, but after installing the magnaflow ill never buy anything else. i felt the power increase after installing the magnaflow and it doesnt resonate cruising down the freeway.keep in mind that i have lt headers, no cats and dumped exhaust with a very healthy cam. if i want noise i just open the cutout. i recently got a magnaflow installed on my 96 z71 and also noticed better throttle response on it. if you insist on a flowmaster get the single chamber, it flows better but its really loud.
I got a 40 series behind the longtubes and ory dumped in front of my axle. It sounds freggin bad *** if you wand loud! Its got some pop during gear change at wot but i love it. Did i mention there is no carpetpad carpet or center section of my bench in the truck rite now damn its hot
If you like the Flowmasters.
look into IMCO mufflers..
they sound like the flowmasters, dont drone as bad, and flow better.
http://www.putfile.com/01thunder
I got a flowmaster 40 and it sounds amazing. I have two turn downs at the back bumper. Sounds amazing and only has slight droning at 1.8-2.2krpm...
no noticeable loss in low end power if anything throttle response was smoother. But then again I put my intake on just weeks after the exhaust..
its been said time and time agian that you only lose 2-3hp at most. which can easily be made up else where..
OVOAustin
Sep 15, 2015 08:32 PM
