Flat torque curve with a LQ4?
Old Aug 21, 2008 | 08:16 PM
turboost's Avatar
Default Flat torque curve with a LQ4?
I just got a 2004 2500 after looking at new Tundra's and Titan's. What I would like to know is what can be done to a 6.0 to have a torque curve like a Tundra or Titan? I know they are a non pushrod motors and they have they're advantages but is there a certain H/C/I combo that could be bolted on a 6.0 that could come on strong off the line and not taper off till 6k rpm?
Old Aug 21, 2008 | 08:27 PM
joeyc125's Avatar
11 Second Truck Club
I'd say with something like a 212-218 comp cam and a cheap set of 243 heads to raise your compression up and a tune for all of it you will whoop on some tundras and tow better than stock. You could do all that for about 1300 and gain about 75-85 horse and equal torque. Or if you don't tow heavy **** alot you could go a little bigger on the cam, or get the heads ported and help power all over.
Old Aug 21, 2008 | 08:30 PM
Silver-Dollar's Avatar
Magnacharger/cam/headers are good for 1200 to 6000 rpms.
Old Aug 21, 2008 | 09:09 PM
GMCtrk's Avatar
I'm not sure what you mean by flat torque curve. The lQ4/LQ9 already has a flat torque curve, mine makes plus or minus 25 ft/lbs or so from 2500 to 5800 rpms. If you are talking about low end torque, the above advice is outstanding. LS6 heads to raise compression and a 210/218 or 212/218 cam to really get some more low end power. Also, you may consider 4.10 gears if you dont have them already.
Old Aug 21, 2008 | 09:56 PM
InchUp's Avatar
Since it's already been said I'll just +3 this post. 243's, 212/218, good tune and you're golden. You're probably looking at 410-415hp and 420-430lb-ft of torque on 87 pump gas. I'd even go as far as saying 20mpg is still possible highway MPG.
Old Aug 22, 2008 | 04:26 AM
Spoolin's Avatar
GFYS and STFU
Cool info...I did not know this either!
Old Aug 22, 2008 | 06:12 AM
SnakeOiler's Avatar
I don't know what a Tundra or Titan torque curve looks like, but I would assume the 6.0 is pretty much a flat liner as it sits. Even my 5.3 is a flat liner: http://i2.photobucket.com/albums/y28...60722small.jpg
Old Aug 22, 2008 | 09:36 PM
turboost's Avatar
By flat torque curve I mean from 2000 rpm to redline. 90% by 25-2800 rpm. After driving all of them, the Tundra/Titan feel stronger way down low. But with the mention head/cam combo I can get 400+ hp and tq (rwhp?) and get a possible 20mpg highway, that sounds like the route I'm looking for. Does this require and fuel delivery enhancements? If I was to change 1 thing, either the heads or cam, which would give me more bang for the buck and lean more towards my goal ( I plan on both but which one first)?
Old Aug 22, 2008 | 09:41 PM
GMCtrk's Avatar
If you get the ls6 heads and 212/218 cam you'll have a bigtime low end. I have crappy 3.42 gears and I can spin the rears at only 2000 rpm with just a tuned stock 6.0
Old Aug 23, 2008 | 08:18 AM
turboost's Avatar
Are the LS6 (243?) heads similar to the 317 heads I have now except for smaller CC to raise compression? Do they flow the same? How much would they raise the compression?
calsdad
Jun 14, 2023 11:07 PM
madmann26
Apr 29, 2020 09:17 AM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Slammed silverado
Sep 28, 2015 06:14 PM
