flaring tool question
Old Sep 10, 2013 | 10:58 PM
greasemykey's Avatar
Default flaring tool question
where can i buy the tool i need to re flare the fuel rail fitting? i need to shorten it and i had debated cutting it off and welding it on but there is not a welder that will do that for me. has anyone done this before?
Old Sep 11, 2013 | 08:53 PM
176 people and no one has a clue how to shorten the supply spring lock fitting to accommodate the vette filter on a return style fuel system?
Old Sep 11, 2013 | 08:57 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You need one of these. Search flea bay. It's the same tool the dealer uses through Kent moore
MASTERCOOL 71475 UNIVERSAL HYDRAULIC FLARING TOOL SET
Old Sep 12, 2013 | 10:20 AM
They are between 300-500 bucks. Does anyone have one I can ship my fuel rail too and have it flared. I cant see buying it and using one time
Old Sep 12, 2013 | 10:37 AM
Beatdown Z's Avatar
Laid Back
I have one of those flaring tools. Haven't tried the "push-connect" flares yet and you're on the other side of the country, sooo...
Old Sep 12, 2013 | 12:30 PM
Im not against shipping the rail to you. I just need to cut it down to adjust for the vette fuel filter.
Old Sep 12, 2013 | 02:03 PM
Mangled03gmc's Avatar
Baltimore Whore
No one in your area will cut it down and re-flare it ? And whats this bad boy look like that needs shortened. I am drawing a blank for some reason lOl
Old Sep 12, 2013 | 03:53 PM
i have called 5 different hose shops and no one knows that a push connect flare is. its the connection that the fuel line connects to on the fuel rail.
Old Sep 12, 2013 | 04:11 PM
Baltimore Whore
So you need some one to flare this ?
Old Sep 12, 2013 | 04:17 PM
Baltimore Whore
A cheap way unless you can have it flared at a shop or buy the fittings to make it work or buy the tool. Is to cut it and put a light flare in each of the cut ends, connect the 2 using a short piece of fuel injection hose and stainless clamps. Not the best way but would work, unless you have it brazed or welded back together after it has been cut to length.
