First INTERCOOLED Whipple Supercharger on a 5.3L!!!
Old Oct 4, 2003 | 08:50 AM
  #21
parish8's Avatar
single digit dreamer
Default Re: First INTERCOOLED Whipple Supercharger on a 5.3L!!!
Did i miss something here,all these kudos and it hasnt even been on the road.i am sure it's fine but i want to here from the boys when they get back from a good thrashing and say"it's better than we thought"
just look at the damn thing, there is no way that set up isn't going to kick ***. after pullying back up to the limit of pump gas i would expect to see 30-60rwhp with that set up.
Old Oct 4, 2003 | 09:07 AM
  #22
parish8's Avatar
just to crunch some numbers for my sake or anyone elses, i ran a 12.77 at 8psi(good gas no nitrous) in my last truck. should be able to run that without the good gas now, probably even do 9psi, then drop 500lbs for no ext cab. even go one step further and run some good gas and 11-12psi. 11's all day long without nitrous!!!! that is a big *** cooler .
if i had that set up i would go one step further and try and do that "super cool" stuff that they were talking about for the concept lighting that was linked to awhile back. is there a rule of thumb for cooler air vs hp?
Old Oct 4, 2003 | 12:37 PM
  #23
Gustin's Avatar
Dammit, how about some info on the LS1 intake swap!
Sean
Old Oct 4, 2003 | 10:34 PM
  #24
Ryan23silverado's Avatar
Hey Gustin I made a post about it that same day man HERE is the extensive post
Old Oct 4, 2003 | 11:02 PM
  #25
hohl's Avatar
Ryan - Where did you come across the pic of the refrigerated intercooler? You worked on "super cooling" your whipple?
Again, looks great and can't wait for the details.
Old Oct 5, 2003 | 01:38 AM
  #26
You brought that to my attention hohl...I updated the site (the one under my posts not the one under my LS1tech bios) with pictures of the ENTIRE project as it progressed. There is some Very cool stuff in the Supercharger album -check it out.
That refridgerated intercooler is one bad *** intercooler. I have heard that with an incomming air temp of 105* it will drop it to 55* MetalMan is the one who showed it to me, and he knows all about it. I don't, because he only sent me a picture and no info.
Old Oct 5, 2003 | 03:32 AM
  #27
sleepersilverado's Avatar
were can info be found on the refridgerated intercooler?
Old Oct 5, 2003 | 04:34 AM
  #28
GoldenVelvet's Avatar
-about sumes it up
Old Oct 5, 2003 | 10:16 PM
  #29
hohl's Avatar
Did you consider one of the refrigerated intercoolers? That's what I meant to ask but my question wasn't clear. More than anything the picture made me curious.
A Google search came up with refrigerated intercooler. Seems like that's where the picture came from too.
Old Oct 5, 2003 | 11:52 PM
  #30
that is a prety cool setup it's like blowing ac in the motor. thanks for the link hohl i did not even try a search for i have not had much luck finding intercoolers through them.
and they are located in houston
