first dyno run
Old Jan 31, 2005 | 10:19 PM
02sierraz71_5.3's Avatar
Default first dyno run
I wanted to get some starting figures before I get into heads and cam. I was disappointed the 5.3 put down 244hp and 300tq with aem intake and 40 series flow. The truck feels alot faster than the figures it put down my 0 to 60 is around 6 sec flat in a z71 ext cab (havent had time to go to the track). The guy tuning it said the 3K stall will suckup alot of HP. The origional tune from a sponsor on here had it running very very rich (which accounts for 12 mpg) and it had 32 degrees of timing . I also had alot of tranny quirckes worked out and after about 2 hours of playing with it I gained 10 hp over the origional tune and it shifts alot better. Im going to have the heads worked slightly (polishing, milled .050, 5 angle valve job and backcut) setup for tr's 224 cam, I guess im going to have the underdrivepulleys put on at the same time. Im thinking about either ASM long tubes or thorley try y (not shore if they have some that fit). With the exhaust I'll gut the cats. Eventually I plan on efans also. When all is said and done I hope to get to around 350 rwhp but, I am begining to wonder if its doable? Am I missing anything? what would you guys do?
Old Jan 31, 2005 | 10:21 PM
these numbers where also with stock 17 rims and tires. I could have put on smaller wheels but that just stupid for a number.
Old Jan 31, 2005 | 10:26 PM
I think thats damn impressive for a Z71! I only made 255 rwhp from a 2wd with about the same mods. And the 0-60 is also very impressive for a ex cab (Thats the same time as my truck accelerates!)
Old Jan 31, 2005 | 10:57 PM
Wheatley's Avatar
Truck Sponsor
Those numbers are not bad at all for a Z71 IMO,6 SEC flat 0-60MPH,you must have a freak man,that is haulin *** in a ext.cab Z71 for damn sure with those mods!
Old Feb 1, 2005 | 04:12 PM
04BlackGmc's Avatar
10 Second Club
i would say they are pretty good.
Old Feb 2, 2005 | 01:26 AM
Kano's Avatar
Im goin to see jeff tomorrow too
0-60 in 6 sec... thats good
I gotta get you to the track
Ill call ya tomorrow!!
Old Feb 2, 2005 | 01:32 AM
MrXerox's Avatar
Am I going to be the first to call B.S. on 0-60 in 6 secs?
Old Feb 2, 2005 | 01:36 AM
F8L Z71's Avatar
The 0-60 doesn't sound right for your mods.
As for your HP you're right on target. I put down 243rwhp with a homemade intake and a magnaflow muffler.
Old Feb 2, 2005 | 04:36 AM
GMC_DUDE's Avatar
Stock, my truck did 0 - 60 in about 8.5 sec. True I have the 4.8, but I also have the RC without all the Z71 ruggedizations. With the Radix, I now consistently do 0 - 60 in 5.7 sec. You can't tell me a n/a 5.3 is as powerful as a blown 4.8.
(edit) Pre Radix, my truck dynoed 240 rwhp 250 ft-lb torque (had headers, cat-back, e-fans). Post Radix it dynoed 314 rwhp, but I think the dyno was messed up as it appears to be more than that.
Old Feb 2, 2005 | 08:03 AM
Not bad!
My 02 5.3l makes 256WHP [B]If I open the air box, and blow a fan directly into the filter. Otherwise I make 247/285.
285x15's, elec. fans, borla catback, hypertech III, 180 stat. and KN filter via stock intake.
Looking to make 285whp w/ +custom intake, high flow cats and HPT???
BTW What Dyno???
