A fire, A lot of repair work and I Need Advice..
I own a 89 K1500 and my engine caught fire due to a bad O ring in one of my injectors but only the rear portion was affected. It burned my wiring harness, distributor, coil, sparkplug wires, all the sensors. I've rebuilt the throttle body, new injectors, new sensors, all new wiring and plugs/wires, all new vacuum hoses but when I finally started it up I had a small amount of white smoke and a good bit of water coming out both sides of my exhaust and it is pulling a lot of air into the carb when I try to accelerate causing it to stall out, it idles good. So what could be the cause? I've done everything I know to do and hoping it's not a cracked head or gasket but just want some input. Thanks
My guess is that you have some screwed up gaskets and are going to need to take the carb all the way off. I am assuming your head gaskets are kaput as well.
Richard
thebrain
03-25-2018 09:46 PM
